8510 max throughput 10gbps only ?
asus zowey
Hello
probably a beginner's question but how can the 8510 controller support 6000 APs in centralized mode when it only has 10Gbps while the 5520 supports 1500 Aps only and has 20 Gbps ?
This table shows the Cisco high-scale Controllers comparison at a glance:
coming to the 8510 controller it has 2 Connectivity(2*10g) ports which is equal to 20g so it can support that it can support 6000 APs.
850075005500WiSM2
Deployment typeEnterprise Large campus + SP Wi-FiCentral site Controller for large number of distributed, controller-less branchesEnterprise Campus and full service branchEnterprise Campus
Operational ModesLocal mode, FlexConnect, MeshFlexConnect onlyLocal mode, FlexConnect, MeshLocal mode, FlexConnect, Mesh
Maximum Scale6000 APs 64,000 clients6000 APs 64,000 clients500 APs 7000 clients1000 APs 15,000 clients
AP Count Range300–6k APs300–6k APs12–500 APs100–1000 APs
LicensingRight to Use (with EULA)Right to Use (with EULA)CISL based (unchanged)CISL based (unchanged)
Connectivity2x10G ports2x10G ports8x1G portsInternal connections to the Catalyst Backplanes
PowerAC/DC dual redundantAC dual redundantAC (redundant PSU option)AC/DC Catalyst chassis redundant PSU option
Maximum Number of FlexConnect Groups20002000100100
Maximum Number of APs per FlexConnect Group1001002525
Maximum Number of Rogue APs Management24,00024,00020004000
Maximum Number of Rogue Clients Management32,00032,00025005000
Maximum Number of RFID50,00050,000500010,000
Maximum APs per RRM Group6000600010002000
Maximum AP Groups60006000500500
Maximum Interface Groups5125126464
Maximum Interfaces per Interface Group64646464
Maximum VLANs Supported40964096512512
Maximum WLANs Supported512512512512
Supported Fast Secure Roaming (FSR) Clients*64000640001400030000
for more info you can look into the below deployment guide link
http://www.cisco.com/c/en/us/support/docs/wireless/8500-series-wireless-controllers/113695-8500-dg-00.html
my point is 2x10g = 20Gbps this should be the max throughput of the device not 10Gbps
also another point how can a controller supporting 6000 APs and 64k clients with only 10 or even 20 Gbps ?
