Showing results forĀ
Search instead forĀ
Did you mean:Ā
881g-4g firmware
davidchulpayev
Hi so ive recently got a second hand 881g-4g cisco router and i need to get the latest firmware for this device...and since im not a cisco costumer i cant realy download it from their site
who can help me get this firmware please
thank you
10 Replies 10
Leo Laohoo
Just want to be clear, you want us to commit copywrite infringement?
Actually i got an email from their support saying i should ask in here that maybe someone have the file i need...if you cant help than you dont have to answer firend
1.  If you were able to contact Cisco "support", would you happen to have the reference number
2.  Unfortunately, only those who have a valid Service Contract can download the firmware.
Just as i said because im not a cisco costumer i cant download from tgeir direct site...anyway if some one can help will appreciate it..thanks
As has been pointed out Cisco software is under license and it would be illegal to share that software.  Anyone doing so would risk legal and commercial sanctions from Cisco.
I can't even see what you're asking for on the Cisco site.  Presuming you're referring to model C881G-4G-GA-K9 (it always helps to be specific) there is no 4G modem software listed for it: https://software.cisco.com/download/home/286259485/type possibly because it's end of sale (albeit not end of support yet) https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/eos-eol-notice-c51-741424.html.  It is already a year past the last date for software maintenance though.
If you know what model of modem it has installed you might be able to find the equivalent firmware under the High Speed WAN interface cards https://software.cisco.com/download/home/279259693.  Then once you have a filename you could try searching for it.  You could also try the modem vendor directly - sometimes they supply OEM firmware but use that at your own risk as that can sometimes brick the modem because it's missing Cisco specific changes that Cisco may have applied for compatibility with their routers.
Ok thank you good to know
Do you have the exact filename of the file you want (HINT:  Look at the Cisco website).
What happens if you use a web search engine with that filename?
c800-universalk9_npe-mz.SPA.157-3.M8.bin
Haven’t tried to search in google actualy
Google is your friend.  Search for "c800-universalk9_npe-mz.SPA" and see the result(s).
Thank you
