88MR2 Interim Build Availability
Sudhagar Singh
We are happy to announce the second refresh of 8.8MR2 Interim build (8.8.114.132) for PRODUCTION deployments.
Access Request: http://cs.co/88Mr2InterimAccess
(Within 24 hours access to software download will be given)
Software Image Download: http://cs.co/88MR2ImageRepository
[NOTE: Please make sure to use Aspera Client to download files, if downloading for the first time from shares.cisco.com you will be prompted to install Aspera Client on top of Website]
Feedback Form: http://cs.co/88MR2Feedback
Base Code: 8.8.111.0
Special Build: 8.8.114.132
8.8.114.132 is the 3rd Interim build published from the 8.8.111.0 CCO image and it is an engineering special that resolves the following additional caveat(s):
8.8.114.132
CSCvi06408
Wave 1 AP failed to send DHCP packet to wired side under VLAN Override
CSCvj71928
Cisco Aironet 1560, 1815, 2800 and 3800 Series Access Point Console Brute Force Protection
CSCvk41603
WLC - Unable to add/delete DCA channels in RF-Profile while Channel width configured as 80 MHz.
CSCvk68688
Client traffic seen on the 5508 Standby Hot WLC causing mac flapping on switch
CSCvm73244
AP3800 in sniffer mode not capturing ACK,RTS in 8.7 and 8.8 CSCvf74377
CSCvn04046
Cisco 2800,3800 AP does not map the DSCP to the correct WMM UP Value for FlexConnect Local Switching
CSCvn07126
Cisco FlexConnect - Cisco 2802 AP's lowers the priority UP on QoS on the downlink transmit
CSCvn23565
Cisco 702w AP enables POE in LAN 4 before joining Cisoc WLC after reboot
CSCvn25524
Throughput is low with Port 2 with 1 Gig SFP on 8540/5520
CSCvn27144
Unable to restore 802.11ac MCS parameter
CSCvn47094
CLI not taking all the commands sent via "paste"
CSCvn49888
702, 1532 AP has tracebacks and beacons stuck with load 8.5.140.0
CSCvn50968
Invalid web-auth https-redirect command in startup-config
CSCvn53514
AP Syslog Facility does not work on IOS AP
CSCvn66715
3800 AP stops passing traffic under client with Interl NIC 8260/8265 load in MU-MIMO deployment
CSCvn80147
BPDU frames are forwarded by the COS AP causing the switch to AP err-disabling port
CSCvn98598
FT 802.1x clients are not able to authenticate to COS AP after Master AP failover
CSCvo02206
Frequent DFS detection - MVL DFS fix
CSCvo04251
dot1x_aaa_eapresp_supp: sending MDNS request to ISE flooding when running "debug client [macaddr]"
CSCvo05093
WLC crash with task name radiusTransportThread
CSCvo06832
Sensor test failed using Open as well as EAP authentication
8.8.114.108
CSCvi77141
HA_send_usmDbSpamSetRadSlotBand, ErrType:Apply Config failed on Standby
CSCvi82746
Cisco controller reloads unexpectedly with Task Name SISF BT Process
CSCvj48316
AP3700: process "QoS stats process" causes unexpected reloads
CSCvk42388
8.3 Flex connect Group is not showing all the APs using GUI
CSCvm84941
Cisco 1600, 1700 APs: memory leak due to packets accumulation
CSCvn17267
702AP: WGB is disconnectig from root AP 'parent lost: Too many retries' RTS when root AP is offchanl
CSCvn20446
Wireless client moves from local switching SSID to central switching SSID DHCP traffic gets dropped
CSCvn32314
Alpha: wcpd crashed seen on 8.8.114.54
CSCvk79597
CSCvn42184
8.8MR2:"/usr/sbin/nginx-helper: line 115: retry++: not found" flooding on 1562 ME WLC Console
CSCvn54782
IGMP snooping needs to be enabled for Local Mode Local switching RLAN.
CSCvn55904
WLC modified FlexACLs rules are not populated on the Flex AP
CSCvn61436
Cisco 5520 controller reloads unexpectedly on taskname : NFV9_Task
CSCvn66293
3802 AP relays CDP Packets from wireless devices using Cisco IP Communicator to the switch
CSCvn68423
Passive client config is lost upon WLC Reload or HA failover
CSCvn68501
WLC LSC : Device certificate can't be installed and showing as "Not Present"
CSCvn71004
WLC Mbuf allocation problem / Mbuf Max reached
8.8.114.94
CSCvi84734
Cisco 702w AP: client intermittently cannot connect- decrypt errors
CSCvj97602
WLC Client RSSI and SNR values to be updated as part of Assoc & reassoc request processing
CSCvk36887
Some clients cannot associate because their entry is not getting deleted at the WLC.
CSCvm11060
WLC: After soft-roam of client, client is not able to see new Apple TV from associated AP-Grp VLAN
CSCvm51648
Cisco WLC open auth guest clients unable to pass traffic and PEM state struck in STATICIP_NOL3SEC
CSCvm60915
Cisco 3800 AP stops passing traffic under client load in MU-MIMO deployment
CSCvm62619
Cisco controller reloads unexpectedly with task emweb after 'debug flexconnect' command is typed
CSCvm69246
Cisco controller applying wrong interface policy to re-associated client after SSO
CSCvm80592
Cisco 2800 AP reloads unexpectedly with ERROR TAMD device 'ap-tam' heartbeat failure
CSCvm83223
AP1832: Kernel panic: PC is at _raw_spin_lock+0x44/0x84
CSCvm90337
Cisco 18xx APs unexpectedly reload due to 'radio failure(radio recovery failed)'
CSCvn00987
AP group NTP config should take precedence
CSCvn03560
Decrypt errors seen on Cisco 702 AP
CSCvn05881
Phone 8821 has roaming issues with 2802/3802 access points MIC mismatch
CSCvn11947
Cisco 1815w:RLAN port'traffic will get stuck at TX direction after end device restarts several times
CSCvn13314
3802/2802: Default SSID "IP Cheetah" broadcasted during AP boot up
CSCvn18615
Ap's couldn't authenticate with ISE 2.5.0.311 when eap method is set as EAP-FAST
CSCvn27111
Alpha WLC crashed due "pmalloc detected memory corruption spamAP Task4 " on 8.8.114.54
CSCvn27902
%SAFEC-3-SAFEC_ERROR observed while decoding iPSK key from radius
CSCvn41979
RLAN port is getting an IP address from native VLAN while AP boot for few seconds
CSCvn68752
1542/1562 Failed to get ARP entry for WLC
14 Replies 14
Haydn Andrews
thanks for the info
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
Are CSCvo05093 & CSCvo04251 going to be included?
Both are fixed already.
CSCvo05093 - Will be part of the next interim refresh.
CSCvo04251 - Will be part of the future interim refresh.
If CSCvo05093 isn't included in 8.8MR2 release then I'll need to regularly reboot the controller (every 10 days).
CSCvo04251 is important because if this doesn't get fixed in 8.8MR2 there is no way I can perform a client debug because my entire screen gets spammed.
Both of the bugs were not present in 8.5.135.0.
Just checked those two bugs, they are now marked as fixed in 8.8.114.x.
Jurgens L
Level 8
Level 8
Can you confirm that AS_7500_8_8_114_108.aes will work on the 5520 series WLC's?
That is the correct image to use on the 5520
-Scott
patoberli
CSCvi82746 finally fixed 🙂
Time to test this.
patoberli
Anybody else unable to SSH into the WLC 3504 since upgrading to this build?
I've tested SecureCRT 8.1.4 (which always worked before) which always had worked until now. It does work if I use a Debian based SSH client.
Just upgraded my SSH client to the latest version, still the same issue.
Was able to solve it in SecureCRT.
I had to edit the Session Options -> Connection -> SSH2 -> Advanced and disable here the option "Enable SSH Agent forwarding". After I disabled this it started to work correctly again.
clockrun
Visitor
My system was previously on version 8.8.110.61. But the upgrade to 8.8.114.132 doesn't work, it still shows that I am on version 8.8.110.61. Tried multiple times to upgrade through TFTP, never worked.
Can you try to upgrade through HTTP in the Webbrowser? Or do you get any error message when upgrading?
