9500 in stackWise and EWC
Guillermo_PY
Level 4
Level 4
Hello Team,
Reading the document https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-744299.html to implement EWC on 9000 series, I see this note:
Note:       HA SSO is not supported with the Catalyst 9400 Series StackWise Virtual setups, nor with the Catalyst 9500 or 9500H Series
And my question: Is necessary to break the stack on my 9500 to deploy EWC?
 No. This means that  If you have 9500 with stackwise you are not going to have HA SSO with EWLC.  That´s it.
You can have EWLC without HA SSO.
5 Replies 5
Hi @Flavio Miranda
Only to reconfirm, Is not necessary to break my 9500 StackWise, but my EWLC will be deployed like a Single switch design as mentioned in the document, right?
that´s correct.  You can build a HA +1 topology instead.
Rich R
@Guillermo_PY are you planning to use SDA EWC and non-SDA EWC?
If non-SDA then take careful note of the warning at the top of that doc:
"Embedded Wireless on Catalyst 9000 Series Switch (non-SDA) using WebUI will be End of Support (Q3FY21) with no additional feature development or code changes and 17.3.x is the last supported release."
non-SDA is already end of support and you won't be able to upgrade beyond IOS-XE 17.3.x which is itself approaching end of life.  If using SDA then no problem - that is still supported.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Guillermo_PY
Level 4
Level 4
@Rich R  thanks for your good observation. I will keep it in mind.
Yes, I have the intention to use it in non-sda
