9800 SSH issue
id404
The local user level is 15, but after ssh login I still need to enter the enable password, is there any way to ssh login without entering the enable password?
username tempuser privilege 15 password 7 XXXXXXXXXXXX
line vty 0 4
privilege level 15
length 0
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
JPavonM
Have you tried adding this?
aaa new-model
aaa authentication login default local
aaa authorization exec default local
-Jesus
*** Please rate helpful responses ***
7 Replies 7
Sandeep Choudhary
I am having this setting and its not asking enable password while login using ssh.
line vty 0 4
length 0
transport input ssh
transport output ssh
line vty 5 15
transport input ssh
Dont forget to rate helpful posts
Referring to the gif I just uploaded, I need to enter the enable password on my device
JPavonM
aaa new-model
-Jesus
You did not show your aaa config - did you do what @JPavonM suggested?
No need to set priv on the VTY, that comes from aaa and user config.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
In my case of lack of access through SSH, I could call port 22, but the admin user did not have CLI access, and these commands solved my problem, thank you very much.
Arshad Safrulla
If you are not using any TACACS or Radius servers for admin authentication and authorization you can disable aaa in the WLC.
no aaa new-model
line vty 0 15
 tran input ssh
 login local
if you are using AAA new model, then you can follow @JPavonM . In case you are using named auth lists, then you need to call it under the line vty.
line vty 0 15
authorization exec ISE-TACACS-AUTHORIZATION
login authentication TISE-TACACS-AUTHENTICATION
transport input ssh
