9800 WLC - CW9166I-A and C9105AXW-A Mesh Configuration
trennissh
Hello all,
I was trying to setup a mesh configuration on our 9800 WLC for C9105AXW-A and CW9166I-A APs. Not specifically between them, but having this scenario working would be great too.
I followed the guide below and when I reached step 7, I did not see an option to select mesh mode at all. At the same time our test AP, which is model AIR-AP3802I-A-K9 did have it in its settings.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215100-join-mesh-aps-to-catalyst-9800-wireless.html
I tried to look up if 9105 and 9166 APs even supported meshing or not, but was not able to find any definitive answer. Did I miss anything or there is no way to configure meshing with these APs at all?
9800 WLC Version: 17.9.4a
AP Firmware: 17.9.4.27
Thanks!
Rasika Nayanajith
Mesh support on Cat 91xx series AP added in 17.12.x firmware. So you have to upgrade your WLC firmware and then test.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-12/release-notes/rn-17-12-9800.html
Rasika
*** Pls rate all useful responses ***
marce1000
 - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-12/config-guide/b_wl_17_12_cg/m_mesh_ewlc.html#restr-mesh-ap
 M.
Rasika Nayanajith
Rasika
Hi @Rasika Nayanajith 17.12.1 only added mesh support for 9130AX, not the whole 91xx range of APs.
Mesh is not currently supported on the 916x APs.
The latest list of supported APs is at:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-14/config-guide/b_wl_17_14_cg/m_mesh_ewlc.html#restr-mesh-ap
Also confirmed in https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc118737962
trennissh
Thank you for your prompt response!
