9800 WLC SMart Licensing 17.3.4
Hi All,
I am trying to register new WLC running 17.3.4 to our On prem CSSM.
We have applied smart config required. Currently we have it set tp cslu method to see if that helps. It shows connection to CSSM restored but gets below error
Mar 8 07:33:18.498 UTC: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart Software Manager (CSSM) : Received empty response from server
Cant find a reason why WLC is not registering/trust with CSSM
11 Replies 11
Mar 8 08:09:30.891 UTC: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : HTTP Server Error 404: Not Found
balaji.bandi
Do you have any FW between Controller and CSSM on-prem ?
check guide :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m_cisco_smart_licensing.html
BB
Doesnt look like a firewall in path. This is in our staging room and dont expect a firewall block
wlc01#telnet ssm 443 /source-interface vl501
Trying ssm (10.x.x.y 443)... Open
Below messages keep coming
Mar 8 08:19:30.956 UTC: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : HTTP Server Error 404: Not Found
Mar 8 08:19:38.655 UTC: %SMART_LIC-5-COMM_RESTORED: Communications with Cisco Smart License Utility (CSLU) restored
Leo Laohoo
Hmmmm ... That's odd.
Please post the complete output to the command "sh crypto pki trustpool | include cn=".
I only want to see the first two lines of the output.
wlc# sh crypto pki trustpool | include cn=
cn=VeriSign Class 3 Public Primary Certification Authority - G5
Can someone share what process to be followed when we have on-prem SSM(Satellite) and 17.3.4 code running on WLC. How is licensing completed?
Do we force to smart or CSLU?
We dont have CSLU running but have another site which runs fine on CSLU method
What version is the CSSM running on?
Because the WLC is on 17.3.4, there should not be any more configuration done with CSL:  Smart License Using Policy
And the WLC should not be affected with FN - 72323 - Cisco IOS XE Software: QuoVadis Root CA 2 Decommission Might Affect Smart Licensing, Smart Call Home, and Other Functionality.
8-202201 CSSM
I wonder if this is CSCwa96336.
Unable to search the bug details
Arshad Safrulla
Can you post your call home configuration
show run | s call-home
show run | s http
You can also consider using http instead of using https. Below is a sample I use.
conf t
call-home
no http secure server-identity-check
profile CiscoTAC-1
no active
profile XXX-Smart-Licensing
reporting smart-licensing-data
destination transport-method http
destination address http http://x.x.x.x/Transportgateway/services/DeviceRequestHandler
destination preferred-msg-format xml
active
exit
ip http client source-interface Vlan999 (Management VLAN)
crypto pki trustpoint SLA-TrustPoint
revocation-check none
end
