9800WLC-in HA red alarm active node
Ramprasad2
Hi team,
i have 9800wlc and configure in SSO mode HA configure but in active node red light showing
how to resolve this issue
balaji.bandi
try below command to guide you what is wrong :
#show facility-alarms status
if you the ports are not connected, if you shutdown you should see green status.
Note : as per the picture you do not have anything connected other than multi-gig ports ?
has this formed HA/SSO ?
show redundancy summay give you more information
BB
balaji.bandi
BB
Ramprasad2
issue has been resolved port shutdown those port not use
