About Error: rdpa_cpu_tx_port_enet_lan#213
ishimura
The following errors are logged on the Catalyst9120 AXI:
ERR: rdpa_cpu_tx_port_enet_lan # 213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=2049
What is the cause of this error and what should I do?
3 Accepted Solutions
marce1000
- As I am on handheld I can not provide the links directly or easily ;
therefore google on
Cisco bug search
Paste the error in the bug search utility , check if anything comes up,
M.
marce1000
  - Also look at the software version being used on the Catalyst 9120 AXI ; use latest advisory , check if that can help to make the particular error message go away ,
 M.
Rich R
Are you actually experiencing some problem with that AP?
If not then don't worry about minor errors in AP logs which are intended mostly for TAC and developers.
If there is an actual problem then describe the problem in detail and include the software version and WLC model details.
As Marce says make sure your software is up to date as per the TAC recommended link below.
5 Replies 5
marce1000
therefore google on
Cisco bug search
M.
Thank you for your comment.
I will check with what you told me.
marce1000
 M.
Rich R
As you pointed out, there are explicit impacts
No, I will check with what you told me.
