Access Point Compatibility question
jason
Community Member
Hi All,
I have a customer who has a WLC 4402 and 4 ancient 1000 series AP's.
They need to extend their wireless estate. I plan to upgrade their controller to 7.0.98.0 and install 10 shiny new AP1142's.
Does anyone know if the 1000 series AP's will still work with 7.0.98.0 ?
I am struggling to find any compatibility information for these old (but perfectly functional) AP's.
Any advice gratefully received,
Jason
5 Replies 5
Rob Huffman
Hi Jason,
You won't like this I'm sure
**Note: Controller software release 5.0.148.0 or later is not compatible with Cisco Aironet 1000 series access points.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn52.html
Cheers!
Rob
Thanks for your help Rob!
That's exactly the info that I needed.
Best regards,
Jason
Rob Huffman
Hey Jason,
You are most welcome! Sorry for being the bearer of bad news.
Cheers!
Rob
Nuts.  Mistakenly clicked the "4" instead of a 5.  Sorry Rob.
rob 5 from me!!
Surendra BG
