ACS and Domain Level
IrishMann
Hello All,
Since I recently updated my MS AD domain lever from 2008 to 2008 R2, my ACS AD authentication no longer works. It appears the Cisco client does not support a 2008 R2 Domain Level. Has anyone ever reverted backwards ?
Cheers
Colin
Surendra BG
I assume the EAP flavour that we are using is added in the authentication methods..
Also change the radius keys on both the ends and see if that helps..
Also please check the server self signed cert as well.. just to double check
and few days back was researching on the issue and found the below link as well
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Server/2000_Server/Q_26295914.html
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Federico Ziliotto
Hi Colin,
Could you please clarify which version of ACS you are using?
For example, if this is ACS 4.2 appliance with a remote agent installed on the Windows server, then Windows 2008 is not supported:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/remote_agent/rawi.html#wp308532
If this is ACS 5.2, then Windows 2008 R2 should be supported:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/user/guide/users_id_stores.html#wp1248491
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
