Advice ou Help cisco air ap2802e e k9
hi to all
I win  a cisco air ap2802e e k9, but a gone use um may house.
i need some help\advice.
I have a router from isp my house with wifi, simple that.
i want com use the Cisco AP to extente the wifi.
What mode i use ? autonomous or lightweight?
And config, there any software to config from desktop, not console with  putty, more simple way.?
thank you
Jorge Quintino
marce1000
 - For starters you will need autonomous for home use. First thing to check is whether it is running an autonomous image to start with.     Google with  related terms will get you on the way.
 M.
Leo Laohoo
Starting with the 2800/3800, there is no more "autonomous".  The AP can be converted into Mobility Express whereby the AP becomes a "mini" WLC (with limited functions) and also acts as an AP.
Convert Capwap 1852 Access Point (AP) to Mobility Express (ME) using Command Line Interface (CLI)
