Air AP 1832 flashes red and no usable output on serial console
gotthardanger
Suddenly one of our 1832 stops working. In serial console I get repeatetly output like this
GPVTG,,T,,M,,N,,K,N*2C
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPGGA,,,,,,0,,,,,,,,*66
$GPRMC,,V,,,,,,,,,,N*53
$GPGSV,3,1,12,01,08,240,,03,45,135,,04,62,240,,06,26,239,*7E
$GPGSV,3,2,12,07,05,340,,08,46,102,,09,,,,11,66,262,*48
$GPGSV,3,3,12,13,02,060,,15,,,,16,46,175,,17,20,284,*44
$GPVTG,,T,,M,,N,,K,N*2C
poe status on switch remains on 1%, link goes to off
led is fast flashing between amber, red and green (end state after approx. 5 minutes)
Is there any chance to get a normal prompt on console?
Thx in advance
Go
6 Replies 6
@gotthardanger normally, when AP flashing all colours that means its trying to find a controller. is this controller based? try changing your baud rate to 9600 in console settings.
Good luck
KB
gotthardanger
yes, it´s controller based. I´m wondering because the ap disconnects from switch (ap doesn´t show up in mac address table of the switch)
changing serial connection to 9600 has no effects
gotthardanger
additional information: I tried some factory rest procedures (mode button - wait until led shows red or amber - release)
the console output doesn´t change. I have to assume the boot code is damaged
@gotthardanger in that situation, its better to contact TAC and try to resolve issue.,
Good luck
KB
Leo Laohoo
RMA the AP.
1800 are well known to have (high) failure rates.
gotthardanger
Support case is opened
