AIR-AP1252AG-A-K9 error
raulzulueta
I have an AIR
-AP-1252AG-A-K9 AP connected to a WS-C3750-48-PS-S and I am getting an error:
%CDP_PD-2-POWER_LOW:  - NON_CISCO-NO_CDP_RECEIVED
What do I need to do to clear this error. The STATUS LED blinks RED.
20 Replies 20
I entered these 2 commands in the AP. I still get this error:
%CDP_PD-2-POWER_LOW:  - NON_CISCO-NO_CDP_RECEIVED  (0000.0000.0000)
What else can you suggest I try?
Thanks.
Can you please do a "sh version"?
What power source is the AP connected to?
TOR-AP1#sh ver
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:44 by prod_rel_team
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(10b)JA, RELEASE SOFTWARE (fc2)
TOR-AP1 uptime is 50 minutes
System image file is "flash:/c1250-k9w7-mx.124-21a.JY/c1250-k9w7-mx.124-21a.JY"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. AIR-AP1252AG-A-K9    (PowerPC 8349) processor (revision A0) with 49142K/16384K bytes of memory.
Processor board ID FTX1209901E
PowerPC 8349 CPU at 533Mhz, revision number 0x0011
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
If
cisco
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:F7:1A:C0:BA
Part Number                          : 73-10425-05
PCA Assembly Number                  : 800-27630-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12071EBM
Top Assembly Part Number             : 800-29039-01
Top Assembly Serial Number           : FTX1209901E
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1252AG-A-K9
Configuration register is 0xF
TOR-AP1#
It is connected to a C3750-48PS-S switch with PoE
Can you reboot the AP and post the show logs after about 5 minutes (takes time for the radios to come up) as well as "sh ip int brief"?
I finally got the IOS loaded. Thanks.
Hello.
good news that your problem is sovled.
can you please let us know what did you do in order to solve the problem?
where was the problem?
Thanks.
