air ap2802i-e-k9
Mady Gueye
Frequent Visitor
Frequent Visitor
Erroe from my new ap2802i-e-k9
see attach.
8 Replies 8
Sandeep Choudhary
The settings in the Hyper Terminal/or Others need to be set correctly; otherwise, "strange-looking" or garbage characters may show up on the screen(As your output in attached file). When you set up the connection, use these settings and try again:
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
Dont forget to rate helpful posts
thanks you for your answer,
i do that but still same
try to change the baud rate ex: 2400, 4800...., 115200  and check again.
stiil same but another new ap2802i-e-k9, all is ok
Either somebody changed the BAUD rate of it, or it's broken.
it's a new AP.
what i do to solve?
If the same settings work for another AP and only not this one, I would return it, marked as "dead on arrival". You maybe need to do an RMA process, check with your reseller.
thank you, i will process to RMA case.
regards,
