AIR-AP3802E-E-K9
m.yildiz
Dear Community,
i bought an AIR-AP3802E-E-K9, also bought 4 Antennas for it.
AIR-ANT2524DW-R DUALBAND.2.4GHz Gain 2dbi and Gain 5GHz Gain 4dbi
My question is the following
Antenna configuration
In the acces Point there is a setting for antenna
Diversity enabled, A,B,C,D,boxes checked
Antenna Gain 5GHZ i put in 4 (x0.5dBI
Antenna Gain 2.4 GHz i put in2 (x0.5dBI)
are these settings correct?
thanks for help.
7 Replies 7
marce1000
  - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/access_point/3800/quick/guide/ap3800iepgetstart.html
   There is a table called  Supported External Antennas , with the needed db settings per antenna-type.
 M.
Thanks for your response.
The Antennas i have are supported,
my question is, if the settings that i made is correct?
I am confused because of the settings
(X 0.5)
Thanks for help
Any help dear community?
Dont forget to rate helpful posts
My settings look different.
cannot choose external.
This how my settings look like
Looks good to me.
Keep as it is. Once you connect the Antennas, AP will adjust its setting automatically.
REgards
