AIR-CAP1552C-A-K9 CPU 100% Utilization
daniel.diaz.g
Hi, community,
I'm presenting an issue in my AP AIR-CAP1552C-A-K9 is raising the CPU utilization to 100%, I would like to know if this problem is coming from a known Bug.
In the Show Process CPU I saw this info too:
Device#show proc cpu
CPU utilization for five seconds: 100%/0%; one minute: 100%; five minutes: 100%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
59 949346508 112540706 8435 99.44% 99.36% 99.32% 0 NCI Rx
Thanks a
2 Accepted Solutions
balaji.bandi
Check there may be BUG associated with a similar problem
BB
Rich R
Always state what version of code you're running - especially relevant for identifying whether a bug is relevant!
CSCvk59498 actually says to track CSCvu02448 for the full fix.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu02448
CSCvu02448 unhelpfully only shows AP code versions not WLC versions so you need to map those back to the relevant controller release using https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#ctr-ap_support
balaji.bandi
BB
Rich R
