AIR-CAP3702I-E-K9 autonomous firmware, SSID is always hidden
Ha Dao
Hi guys
I configure an AP: AIR-CAP3702I-E-K9 with autonomous firmware, but somehow I never seen the SSID name. It look like in Hidden mode (I still can connect my SSID by Hidden Network on win 10). How can I make it available ? 
You can see the blue SSID is empty name, I am sure that is from my AP I configuring.
I miss this command, it work now, thank
dot11 ssid TEST
guest-mode
marce1000
 - Check WLAN parameters for the particular SSID in the GUI of the ap-management , or use another SSID for the WLAN as an (example) sanity check.
 M.
Rich R
dot11 ssid SSID-NAME
vlan XX
authentication ......
mbssid guest-mode     <- This enables broadcast of the SSID
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3-JB/configuration/guide/cg_book/cg-chap7-mbssid.html
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap7-mbssid.html
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/service-set-identifier-ssid/210516-SSIDs-and-VLANs-configuration-on-Autonom.html
dot11 ssid TEST
guest-mode
