AP c9115axe-e not joined on wlc 3504 after firmware upgrade.
davidkirungu89
 We recently purchased the AP c9115axe-e and once we upgraded the firmware of WLC as cisco recomended we still cannot join the APs. What could be the issue?
marce1000
 - Ref : https://www.cisco.com/c/en/us/support/docs/field-notices/724/fn72424.html   , note that for aireos controllers like 3504  , you need at least  8.10.18x.0 or later  to resolve this issue (if the access point is 'affected')
 M.
7 Replies 7
davidkirungu89
The controller is wlc 3504
JPavonM
Do you have console output from AP? Tjhis is the most valuable information to troubleshoot join problems.
Which commands should i run, once i connect the AP to my console??
Will try and get output today
marce1000
 M.
JPavonM
With a console connected, reboot AP from scratch and log all ouput to a file and share please.
Rich R
What version of software do you have installed on the WLC?
What version of software is the AP running (you'll get that from the console logs on the AP)?
