AIR-CT3504-K9 compatibility with AIR-CAP2702E
MABUZAID
Dear all,
Kindly can you confirm if  AIR-CT3504-K9 will be compatible with 6 AIR-CAP2702E.
Sandeep Choudhary
Yes they are compatibie.
Dont forget to rate helpful posts
patoberli
Once you have received it, upgrade to 8.5.140.0 or 8.8.111.0.
Haydn Andrews
Yes they are.
The 3504 requires a minimum of 8.5.x code, the 2700 series APs will support this and currently all released WLC code sets.
For future reference on AP/ WLC and code compatibility make sure you book mark the Wireless Compatibility matrix page:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
Yes, 3504 will support 2702.
I recommend loading the WLC with latest 8.5 code when running AP2700/3700.
