AIR-CT7510-K9 CLI command
abinaya.2.r
Level 4
Level 4
Hi all,
Can you please tell me the CLI  command to check what is the SFP model connected to the WLC. The WLC model is
AIR-CT7510-K9.
5 Replies 5
Rasika Nayanajith
Try below command
show inventory raw | in SFP-
https://mrncciew.com/2014/08/18/wlc-sfp-info/
Rasika
*** Pls rate all useful responses ***
I tried this. I don't get any result
(Cisco Controller) >show inventory raw | in SFP-
Incorrect input! Use 'inventory'
Sorry, I read it as 5760.
If it is AireOS, you can try the below command. Refer that blog post
(Cisco Controller) >debug fastpath cfgtool --dump.sfp
Rasika
*** Pls rate all useful rate ***
(Cisco Controller) >FP0.
FP0.
Port SFP Vendor       Transceiver Type    OUI PartNumber       Rev  SerialNumber     DateCode Auth
   1 Not Present      (0x00)NOT_SUPPORTED                                                     fail
   2 Not Present      (0x00)NOT_SUPPORTED                                                     fail
I get this above result.. does it mean there is no SFP here?  this is a 7510 model and sfp ports.
Could also mean it's not a Cisco SFP. If you can go on-site and you have an active LAG / Etherchannel, you might simply unplug one and check it.
