ā09-23-2020 12:51 AM - edited ā07-05-2021 12:32 PM
please is the AP AIR-CAP2602E-E-K9 compatible with the wlc 4400 version 7.0.235.3? would it register on it?
Solved! Go to Solution.
ā09-24-2020 08:25 AM
No, never had 7.2. Support for the 4400 series was removed in 7.2 (or even 7.1).
Here it's documented: https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn7_2_111_3.html
ā09-23-2020 01:10 AM
Won't work.
2600 supported firmware is 7.2.X.X.
ā09-23-2020 01:21 AM
if i upgraded my 4400 to 7.2.X.X would my existing AIR-LAP1252G-E-K9 and AIR-CAP3501E-E-K9 still work?
ā09-23-2020 01:40 AM
Please refer to Cisco Wireless Solutions Software Compatibility Matrix.
ā09-23-2020 01:45 AM
wlc 4400 being EOL is there a way to download firmware 7.2?
ā09-23-2020 01:57 AM
Officially, no.
Once a product has gone past the End of Support date, Cisco removes all documentation(s) and file(s) from the public.
The only way to get the file is to search the internet for the exact filename.
ā09-23-2020 02:09 AM
any idea if wlc 4400 even had a 7.2 version to begin with??
ā09-23-2020 08:05 AM
You need to do that research... that model is so old, I can't even remember what code or ap's that supported. Find a used 2504 or maybe even a 3504. The issue you will have is downloading the images, since a contract is required.
