AIR-CT8510-K9 dtl Driver Init Failure
LACOFIRE001
Controller is on a reboot loop
On boot I tried to clear the configuration and setup from scratch but the system crashes during the process, and reboots, systems never boots to GUI or CLI
Summary Below : Full Log is attached
Sys Name:
Model: AIR-CT8510-K9
Version: 8.3.143.0
Timestamp: Mon Apr 5 12:06:35 2021
SystemUpTime: 0 days 0 hrs 2 mins 57 secs
pid: 1615
TID: -26380544
Task Name: osapiBsnTimer
User Crash: dtl Driver Init Failure
Timer Current Time :123 secs
Analysis of Failure:
Software was stopped for the following reason:
Message Logs
*osapiBsnTimer: Apr 05 12:05:45.060: %LOG-3-MSG_USER_RESET_CRASH: log.c:1704 Serviceability crash or reset is triggered from : cnfgr.c : 392 Errorcode: 16
*dtlArpTask: Apr 05 12:05:44.758: %DTL-3-DSINTF_SET_FAILED: dtl_ds.c:120 Unable to configure the Distribution Service Interface unit/slot/port.
*mmMobility: Apr 05 12:05:42.253: %DTL-3-ARP_SEND_FAILED: dtl_net.c:698 Could not send ARP request to f4:cf:e2:09:f8:e0. VLAN=0, Intf=1. invalid vlan or interface.
*dtlArpTask: Apr 05 12:05:41.754: %DTL-3-DSINTF_SET_FAILED: dtl_ds.c:120 Unable to configure the Distribution Service Interface unit/slot/port.
*dtlArpTask: Apr 05 12:05:38.750: %DTL-3-DSINTF_SET_FAILED: dtl_ds.c:120 Unable to configure the Distribution Service Interface unit/slot/port.
*osapiReaper: Apr 05 12:05:37.097: %SYSTEM-3-SYSAPI_ERR: sysapi.c:162 System Error : dapi.c 401: In dapiCtl() dapiInit has not been called successfully
6 Replies 6
patoberli
Looks like a software bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh69616/?rfs=iqvred
Best to contact TAC, as it doesn't look to be fixed in published 8.3.x releases.
Makram
any fix for above issue
It's fixed in 8.5.151.0 and later.
Do you actually see the exactly same error or some other one?
Makram
its not allowing to upgrade or downgrade the software.
its keep on rebooting and displayed same error.
dtl driver not initited
Can you boot the backup image?
Makram
active and backup having same image
