Aironet 1140: from lwap to autonomous AP
Carlo Zaina
Just this: is it possible to downgrade a 1140 from lwap to autonomous AP?
33 Replies 33
Although it does not say anything about WMM anywhere on the GUI, I was able to follow some documentation online and finally got it. It was indeed the WMM. I enabled it along with the WPA2 and I was able to get the full speeds on the N laptops. Thank you for the feedback
alessandro.dona
Level 3
Level 3
can you kindly post which IOS version did you use for conversion.....thx
The conversion (explained in the above replies) has been done using the image c1140-k9w7-mx.124-21a.JA1
ap#show version
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
ap uptime is 3 weeks, 5 days, 21 hours, 24 minutes
System restarted at 23:13:36 Berlin Wed Mar 31 2010
System image file is "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/customer/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Don't forget to rate our posts.  Thanks.
