aironet problem
sabi20714
Community Member
I bougth cisco Aironet 1250 series few days ago, after configuration window 7 clients were able to (Associate) access interrnet through it but window XP clients didn't access internet(associate) through it, after all troubleshooting i decided upgrade to ios version 124-21a.ja2 the previous version was 124-10b.da3. After upgrading the system reported an error unknown and return to ROM and repeat restartin after sometimes and does support copy command to restore previous ios. any one with help i need to make it run
Surendra BG
21a.JA2 is the LWAPP code not IOS.. if we load LWAPP image on to the IOS AP then the reboot is expected since it will search for the WLC to get registered..
If we stil have the AP in LWAPP mode then use the below link to get the AP back to IOS.. (LWAPP to IOS conversion)
https://supportforums.cisco.com/docs/DOC-14960
Download the image from the below link..
http://www.cisco.com/cisco/software/cart.html?mdfid=&treeMdfId=278875243&flowid=6779&addoption=DN&imageGuId=FE752847E6D5446CE655500E3BC32496440548CD&isLatestRel=Y
lemme know if htis answered ur question and please done forget to rate the usefull posts!!
Surendra
Surendra BG
sabi20714
Community Member
hi
Thanks for your consern,
i have failed to download ios i dont have contract.
can anyone help me pls
Regard
James
