Andriod device and other some thin clients devices not connecting via
ramlakshmanan9500
Community Member
Android device and some other thin clients devices are not connecting using Cisco AP-9210 using 9200 WLC.But, windows devices are connecting and working properly.
marce1000
          - Connect to a AP-9210 and issue the command    show  ap client-trace events mac aa:bb:cc:01:02:03
             change the mac address to that of an android device that you are testing , then let it connect to the AP and observe the output ,
 M.
Rich R
@ramlakshmanan9500 I guess you mean 9120 AP and 9800 WLC?
What version of software are you using?
How is the WLAN configured?
Have you checked https://bst.cisco.com/bugsearch/bug/CSCvu24770 ?
JPavonM
If you're SSID is configured for dot1X, some devices need you to setup the profile manually as they don't recognize it, as Linux-based ones such as Androids.
