WLC 5508 - DOT1X RESTARTED DUE TO EAPOL-START/CLIENT ROAM
enzo99
Hello guys,
since a few days we've been facing an issue on one of our main production sites.
Other locations seem to be fine at the moment.
The problem is that some of the users can't authenticate to our primary SSID which is secured by 802.1X.
We are using a WLC 5508 Cluster with product version: 8.5.182.0 and the supplementary ap bundle.
Checking the WLC-Logs the detailed error message is: DOT1X RESTARTED DUE TO EAPOL-START/CLIENT ROAM
The radius request does not arrive on the NPS, neither an accept or deny response is generated.
The problem seems to be getting worse.
We planned on disabling FT (Fast Transition) as it was recommended in an other post with a similiar issue. Furthermore we did not update/change the intel NIC Firmware Version.
Has anyone of you got an idea where the problem might be ?
Thank you in advance!
marce1000
       >...The problem is that some of the users can't authenticate to our primary SSID which is secured by 802.1X.
  - You should debug the client on the controller with commands as in :
                          (WLC) >debug client aaaa.bbbb.cccc
     Client debugs can be analyzed with : Wireless Debug Analyzer
  - For the controllers where the problems are occurring review the controller configuration using :
    WirelessAnalyzer input (procedure) for AireOs controllers
    and feed the output from that into Wireless Config Analyzer
  - High importance as per : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
    For the 5508 that comes down to using : https://software.cisco.com/download/specialrelease/9a6a7cf84f9fdf04b95c76e2ac7820e7  because of the platform being EOL kind of always use the latest available release , because support is diminishing too.
  - Related to above : plan migration to the 9800 platform for future solid business support ,
 M.
marce1000
 M.
Rich R
Marce has covered most of the options for you there already.
Since your options are limited at this point you can also think about reloading APs and if that doesn't help reload the WLC.
Upgrading to 8.5.182.12 will do both anyway so that should probably be your first action point.
It goes without saying that Intel drivers should be updated - the older drivers cause no end of problems.
enzo99
we will try your suggestion of upgrading the wlc to the newest firmware. We have already rebooted the wlc and the APs in the affected area several times. I'll let you know as soon as we have aquired the new firmware and upgraded the WLCs accordingly.
Thanks for your help so far.
