Antenna Ranges
mreilly
Does anyone know if there is a document that specifies the ranges for each antenna? I am trying to find out the coverage for a patch antenna.
jasyoung
Level 7
Level 7
Try this document for range and other properties on several types of antennas compatible with Aironet access points:
http://www.cisco.com/en/US/customer/products/hw/wireless/ps469/products_data_sheet09186a008008883b.html
Saurav Lodh
Level 7
Level 7
Please refer the attachment for different antennae
Scott Fella
You responded to a post from 2003:)
-Scott
Ravi Singh
Level 7
Level 7
I would recommend you to go through to the below link.
http://www.home.agilent.com/upload/cmc_upload/All/ORFR-Theory.pdf?&cc=IN&lc=eng
http://www.antenna-theory.com/measurements/antenna.php
The above two link will describe how to measure antenna range.
