AP 1200 Inline Power
nicol.dunlop
Community Member
Does anyone know if the AIR-AP1200 comes with an inline power injector unit included, or must they be ordered seperately ?
fjuch
Cisco sells the injector as a separate part. Also I have been told if you have both radios installed, the Cisco inline power switches do not provide enough power for the added load. Then you must use an inline injector.
bmath
You have to order it seperately even the antenas.
