AP 1562I-D-K9 not able to configured
anilkumar.cisco
Level 4
Level 4
While powering on AP 1562 first time, I am getting the below error..
Not able to configured it..
Either using Switch POE or Power injectory (AIR-PWRINJ5)
pls help
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.03.27 16:27:04 =~=~=~=~=~=~=~=~=~=~=~=
[*06/28/2017 00:06:58.2996] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:06:58.3470] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:07:00.3469] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:07:00.3943] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:07:02.3941] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:07:02.4417] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:07:04.4413] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:07:04.4889] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:07:06.4886] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:07:06.5360] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:07:08.5359] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:07:08.5833] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:07:10.5831] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:07:10.6307] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:07:12.6305] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:07:12.6779] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:07:14.6777] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:07:14.7264] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:07:16.7250] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:07:16.7726] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:07:18.7724] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:07:18.8200] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:07:20.8197] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:07:20.8671] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:07:22.8670] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:07:22.9144] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:07:24.9142] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:07:24.9616] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:07:26.9614] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:07:27.0089] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:07:29.0087] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:07:29.0563] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:07:31.0588] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:07:31.1064] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:07:33.1061] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:07:33.1537] DOT11_DRV[1]: set_channe��������������������������������������������������������������nk Up: mac: A0:23:9F:FA:06:28 BH Id: 0 GW_reachable: No Roam: false
[*06/28/2017 00:07:48.8490] driver_wpas: - wpa_driver_wpas_init
[*06/28/2017 00:08:03.0577] Resetting wired0 and[06/28/2017 00:08:03.0800] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
srcr6, ifconfig[06/28/2017 00:08:03.2000] wired0: stopped
down up
[*06/28/2017 00:08:03.2728] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:08:05.2800] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:08:05.3800] wired0 emac 1: link up
[06/28/2017 00:08:05.4300] wired0: link up
[06/28/2017 00:08:05.4800] wired0: started
[*06/28/2017 00:08:05.5397] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:08:05.5412] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
�þÖ�
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.14
High speed PHY - Version: 2.0
BoardId = 0x23board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-g729a7b4 (Dec 05 2016 - 23:44:32) SDK version: 2015_T2.0p10
Board: Milos
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
NAND: 256 MiB
SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fedc000:0x3ffad730
BSS: 0x3ffef1d4
Stack: 0x3f9cbf20
Heap: 0x3f9cc000:0x3fedc000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
SFP not detected, enable RJ45
Net: , egiga1 [PRIME]
Hit ESC key to stop autoboot: 3  2  1  0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 0, name "part1"
Loading file 'part1/part.bin' to addr 0x02000000 with size 33710861 (0x0202630d)...
Done
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2017-05-17 17:53:15 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 33709853 Bytes = 32.1 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4112888 Bytes = 3.9 MiB
Image 1: 29581199 Bytes = 28.2 MiB
Image 2: 15749 Bytes = 15.4 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x040221d8
Loading Multi-File Image ... OK
OK
Loading Device Tree to 01ff9000, end 01fffd84 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Unable to update property /soc/gop/mac2:local-mac-address, err=FDT_ERR_NOSPACE
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
WARNING: could not set reg FDT_ERR_NOSPACE.
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:10.4000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:10.5100] Memory: 999156K/1048576K available (5540K kernel code, 413K rwdata, 2572K rodata, 347K init, 465K bss, 49420K reserved)
[01/01/1970 00:00:10.6600] CPU1: Booted secondary processor
[01/01/1970 00:00:10.7200] buginf tty flushing thread started, ttyport=bf13b800
[01/01/1970 00:00:10.9500] m25p80 spi1.0: found n25q032a, expected n25q032
[01/01/1970 00:00:11.5600] lp5521 0-0030: device detection err: -6
[01/01/1970 00:00:12.4000] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 20, need 32
[*01/01/1970 00:00:12.5710] buginf() enabled.
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
[*01/01/1970 00:00:12.5895] Made it into bootsh: May 17 2017 10:47:20
[*01/01/1970 00:00:12.6017] bootsh build T-ea744460b77c6aa805022a071636bbe91bfbef81-gea744460-kalairam
[*01/01/1970 00:00:13.7803]
init started: BusyBox v1.23.2 (2017-05-17 10:28:41 PDT)
Jan 1 00:00:15 FIPS[3177]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:18.3853]
[*01/01/1970 00:00:18.3853] Authenticating ACT2 ID:AP1560
[*01/01/1970 00:00:18.3853] Authenticating SN:JPI212506QE
[*01/01/1970 00:00:18.3857]
[*01/01/1970 00:00:18.3857] (ACT2Boot) Hardware is Cisco (c) authentic
[*01/01/1970 00:00:18.3857] Seeding /dev/urandom from ACT2
[*06/27/2017 23:59:59.0064] Last reload time: Jun 27 23:59:59 2017
[*06/27/2017 23:59:59.0001] Setting system time Tue Jun 27 23:59:59 UTC 2017
[*06/27/2017 23:59:59.1139] Loading kernel crypto modules
[*06/27/2017 23:59:59.2352] GCM-128 POST passed
[*06/27/2017 23:59:59.2352] GCM-256 POST passed
[*06/27/2017 23:59:59.3954] Active version: 8.4.100.0
[*06/27/2017 23:59:59.3966] Backup version: 0.0.0.0
[*06/27/2017 23:59:59.5691] devi[06/27/2017 23:59:59.5800] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
ce wired0 entere[06/27/2017 23:59:59.6700] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
d promiscuous mode
[*06/28/2017 00:00:00.9459] 0;0;0;0;0;0;0;
[*06/28/2017 00:00:02.5139] Firmware download complete
[*06/28/2017 00:00:02.5320] FIPS enc aes-ccmp Verified
[*06/28/2017 00:00:02.5321] FIPS dec aes-ccmp Verified
[*06/2[06/28/2017 00:00:02.6700] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
8/2017 00:00:02.[06/28/2017 00:00:02.7700] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
5323] FIPS enc aes-ccmp-256 Verified
[*06/28/2017 00:00:02.5324] FIPS dec aes-ccmp-256 Verified
[*06/28/2017 00:00:02.5325] FIPS enc aes-gcmp Verified
[*06/28/2017 00:00:02.5326] FIPS dec aes-gcmp Verified
[*06/28/2017 00:00:02.5327] FIPS enc aes-gcmp-256 Verified
[*06/28/2017 00:00:02.5328] FIPS dec aes-gcmp-256 Verified
[*06/28/2017 00:00:04.0408] 0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;
[*06/28/2017 00:00:08.3084] Firmware download complete
[*06/28/2017 00:00:08.3265] FIPS enc aes-ccmp Verified
[*06/28/2017 00:00:08.3266] FIPS dec aes-ccmp Verified
[*06/28/2017 00:00:08.3267] FIPS enc aes-ccmp-256 Verified
[*06/28/2017 00:00:08.3268] FIPS dec aes-ccmp-256 Verified
[*06/28/2017 00:00:08.3269] FIPS enc aes-gcmp Verified
[*06/28/2017 00:00:08.3270] FIPS dec aes-gcmp Verified
[*06/28/2017 00:00:08.3272] FIPS enc aes-gcmp-256 Verified
[*06/28/2017 00:00:08.3273] FIPS dec aes-gcmp-256 Verified
[*06/28/2017 00:00:08.7927] ifconfig: SIOCGIFFLAGS: No such device
[*06/28/2017 00:00:08.9014] Initializing NSS Firmware
[06/28/2017 00:00:12.0400] Disabling lock debugging due to kernel taint
[*06/28/2017 00:00:12.0564] stile_lm_ft_barbados: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[*06/28/2017 00:00:12.1513] stile module dp init successfully
[*06/28/2017 00:00:12.1513] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Mar 6 2017 at 12:16:50
[*06/28/2017 00:00:13.6454] Loading nf_conntrack...
[*06/28/2017 00:00:13.6634] Loading nf_conntrack_ftp...
[*06/28/2017 00:00:13.6747] Loading nf_defrag_ipv4...
[*06/28/2017 00:00:13.6857] Loading nf_defrag_ipv6...
[*06/28/2017 00:00:13.6970] Loading nf_conntrack_ipv4...
[*06/28/2017 00:00:13.7084] Loading nf_conntrack_ipv6...
[*06/28/2017 00:00:13.7198] Loading nf_conntrack_irc...
[*06/28/2017 00:00:13.7310] Loading nfnetlink...
[*06/28/2017 00:00:13.7421] Loading nf_conntrack_netlink...
[*06/28/2017 00:00:13.7534] Loading nf_conntrack_sip...
[*06/28/2017 00:00:13.7648] Loading nf_nat...
[*06/28/2017 00:00:13.7761] Loading nf_nat_ftp...
[*06/28/2017 00:00:13.7873] Loading nf_nat_ipv4...
[*06/28/2017 00:00:13.7985] Loading nf_nat_irc...
[*06/28/2017 00:00:13.8098] Loading nf_nat_sip...
[*06/28/2017 00:00:13.8210] Loading x_tables...
[*06/28/2017 00:00:13.8325] Loading xt_conntrack...
[*06/28/2017 00:00:13.8437] Loading xt_state...
[*06/28/2017 00:00:13.8548] Loading xt_nat...
[*06/28/2017 00:00:13.8659] Loading xt_tcpudp...
[*06/28/2017 00:00:13.8775] Loading ip_tables...
[*06/28/2017 00:00:13.8887] Loading iptable_filter...
[*06/28/2017 00:00:13.9000] Loading iptable_mangle...
[*06/28/2017 00:00:13.9114] Loading iptable_nat...
[*06/28/2017 00:00:13.9229] Loading ip6_tables...
[*06/28/2017 00:00:13.9344] Loading ip6t_REJECT...
[*06/28/2017 00:00:13.9456] Loading ip6t_ipv6header...
[*06/28/2017 00:00:13.9568] Loading ip6table_filter...
[*06/28/2017 00:00:13.9682] Loading ip6table_mangle...
[*06/28/2017 00:00:13.9794] Loading ipt_MASQUERADE...
[*06/28/2017 00:00:13.9907] Loading ipt_REJECT...
[*06/28/2017 00:00:14.0021] Loading iptable_raw...
[*06/28/2017 00:00:14.0136] Loading ip6table_raw...
[*06/28/2017 00:00:14.0249] Loading bridge...
[*06/28/2017 00:00:14.0399] Loading nfnetlink_log...
[*06/28/2017 00:00:14.0514] Loading xt_mark...
[*06/28/2017 00:00:14.0628] Loading xt_policy...
[*06/28/2017 00:00:14.0740] xt_tcpudp is already loaded
[*06/28/2017 00:00:14.0741] Loading ebtables...
[*06/28/2017 00:00:14.0855] Loading [06/28/2017 00:00:15.8100] wired0 emac 1: link up
ebt_ip...
[*06/[06/28/2017 00:00:15.8800] wired0: link up
28/2017 00:00:14.0970] Loading ebt_ip6...
[*06/28/2017 00:00:14.1084] Loading ipt_ULOG...
[*06/28/2017 00:00:14.2359]
[*06/28/2017 00:00:14.2397] boot 4 build T-ea744460b77c6aa805022a071636bbe91bfbef81-gea744460-kalairam board barbados mac A0:23:9F:FA:06:28
[*06/28/2017 00:00:14.2427] Module: act2_driver .text=0x7f000000 data=0x7f000770 bss=0x7f000a04
[*06/28/2017 00:00:14.2427] Module: aes_generic .text=0x7f004000 data=0x7f00a460 bss=
[*06/28/2017 00:00:14.2427] Module: sha256_generic .text=0x7f00e000 data=0x7f00fbdc bss=
[*06/28/2017 00:00:14.2428] Module: sha512_generic .text=0x7f014000 data=0x7f0158c8 bss=
[*06/28/2017 00:00:14.2428] Module: hmac .text=0x7f019000 data=0x7f0195e8 bss=
[*06/28/2017 00:00:14.2428] Module: sha1_generic .text=0x7f01d000 data=0x7f01d2cc bss=
[*06/28/2017 00:00:14.2428] Module: sha1_arm .text=0x7f021000 data=0x7f021850 bss=
[*06/28/2017 00:00:14.2428] Module: gf128mul .text=0x7f025000 data= bss=
[*06/28/2017 00:00:14.2428] Module: cbc .text=0x7f02a000 data=0x7f02a4f4 bss=
[*06/28/2017 00:00:14.2428] Module: ctr .text=0x7f02e000 data=0x7f02e7c8 bss=
[*06/28/2017 00:00:14.2428] Module: ghash_generic .text=0x7f032000 data=0x7f032268 bss=
[*06/28/2017 00:00:14.2428] Module: seqiv .text=0x7f036000 data=0x7f036654 bss=
[*06/28/2017 00:00:14.2428] Module: mbedtls .text=0x7f03a000 data=0x7f0415e0 bss=0x7f041850
[*06/28/2017 00:00:14.2428] Module: aptrace .text=0x7f046000 data=0x7f04dc50 bss=0x7f04e0b8
[*06/28/2017 00:00:14.2428] Module: ap8x .text=0x7f055000 data=0x7f1066b0 bss=0x7f10deac
[*06/28/2017 00:00:14.2428] Module: mv_nss_api .text=0x7f2e8000 data=0x7f336cd8 bss=0x7f3380e8
[*06/28/2017 00:00:14.2428] Module: proclikefs .text=0x7f349000 data= bss=0x7f349b80
[*06/28/2017 00:00:14.2428] Module: stile_lm_ft .text= data= bss=
[*06/28/2017 00:00:14.2428] Module: stile_lm_dp .text= data= bss=
[*06/28/2017 00:00:14.2428] Module: mtdoops .text=0x7fe21000 data=0x7fe21e34 bss=0x7fe21fa8
[*06/28/2017 00:00:14.2428] Module: ipv6 .text=0x7fe26000 data=0x7fe5bb40 bss=0x7fe5d700
[*06/28/2017 00:00:14.2428] Module: llc .text=0x7fe84000 data=0x7fe84864 bss=0x7fe84a00
[*06/28/2017 00:00:14.2428] Module: stp .text=0x7fe89000 data=0x7fe89280 bss=0x7fe8943c
[*06/28/2017 00:00:14.2429] Module: nf_conntrack .text=0x7fe8d000 data=0x7fe96b50 bss=0x7fe9785c
[*06/28/2017 00:00:14.2429] Module: nf_conntrack_ftp .text=0x7fea7000 data= bss=0x7fea8380
[*06/28/2017 00:00:14.2429] Module: nf_defrag_ipv4 .text=0x7feac000 data=0x7feac188 bss=
[*06/28/2017 00:00:14.2429] Module: nf_defrag_ipv6 .text=0x7feb0000 data=0x7feb1070 bss=0x7feb12c0
[*06/28/2017 00:00:14.2429] Module: nf_conntrack_ipv4 .text=0x7feb7000 data=0x7feb8d88 bss=0x7feb9218
[*06/28/2017 00:00:14.2429] Module: nf_conntrack_ipv6 .text=0x7febf000 data=0x7fec01bc bss=
[*06/28/2017 00:00:14.2429] Module: nf_conntrack_irc .text=0x7fec5000 data=0x7fec557c bss=0x7fec5a24
[*06/28/2017 00:00:14.2429] Module: nfnetlink .text=0x7fec9000 data=0x7fec9a34 bss=0x7fec9bac
[*06/28/2017 00:00:14.2429] Module: nf_conntrack_netlink .text=0x7fece000 data=0x7fed1a5c bss=
[*06/28/2017 00:00:14.2429] Module: nf_conntrack_sip .text=0x7fed7000 data= bss=0x7fedaf44
[*06/28/2017 00:00:14.2429] Module: nf_nat .text=0x7fee0000 data=0x7fee1f90 bss=0x7fee21b0
[*06/28/2017 00:00:14.2429] Module: nf_nat_ftp .text=0x7fee8000 data=0x7fee8320 bss=
[*06/28/2017 00:00:14.2429] Module: nf_nat_ipv4 .text=0x7feec000 data= bss=0x7feec91c
[*06/28/2017 00:00:14.2429] Module: nf_nat_irc .text=0x7fef0000 data=0x7fef0254 bss=
[*06/28/2017 00:00:14.2429] Module: nf_nat_sip .text=0x7fef4000 data=0x7fef57d8 bss=
[*06/28/2017 00:00:14.2429] Module: x_tables .text=0x7fef9000 data=0x7fefb184 bss=0x7fefb2fc
[*06/28/2017 00:00:14.2429] Module: xt_conntrack .text=0x7ff02000 data= bss=
[*06/28/2017 00:00:14.2429] Module: xt_state .text=0x7ff06000 data= bss=
[*06/28/2017 00:00:14.2429] Module: xt_nat .text=0x7ff0a000 data= bss=
[*06/28/2017 00:00:14.2430] Module: xt_tcpudp .text=0x7ff0e000 data= bss=
[*06/28/2017 00:00:14.2430] Module: ip_tables .text=0x7ff12000 data=0x7ff13eb4 bss=0x7ff1412c
[*06/28/2017 00:00:14.2430] Module: iptable_filter .text=0x7ff18000 data=0x7ff181b0 bss=
[*06/28/2017 00:00:14.2430] Module: iptable_mangle .text=0x7ff1c000 data=0x7ff1c210 bss=
[*06/28/2017 00:00:14.2430] Module: iptable_nat .text=0x7ff20000 data=0x7ff205bc bss=
[*06/28/2017 00:00:14.2430] Module: ip6_tables .text=0x7ff24000 data=0x7ff25f50 bss=0x7ff261c8
[*06/28/2017 00:00:14.2430] Module: ip6t_REJECT .text=0x7ff2a000 data= bss=
[*06/28/2017 00:00:14.2430] Module: ip6t_ipv6header .text=0x7ff2e000 data= bss=
[*06/28/2017 00:00:14.2430] Module: ip6table_filter .text=0x7ff32000 data=0x7ff32174 bss=
[*06/28/2017 00:00:14.2430] Module: ip6table_mangle .text=0x7ff36000 data=0x7ff36284 bss=
[*06/28/2017 00:00:14.2430] Module: ipt_MASQUERADE .text=0x7ff3a000 data=0x7ff3a2a8 bss=
[*06/28/2017 00:00:14.2430] Module: ipt_REJECT .text=0x7ff3e000 data= bss=
[*06/28/2017 00:00:14.2430] Module: iptable_raw .text=0x7ff42000 data=0x7ff4217c bss=
[*06/28/2017 00:00:14.2430] Module: ip6table_raw .text=0x7ff46000 data=0x7ff46140 bss=
[*06/28/2017 00:00:14.2431] Module: bridge .text=0x7ff4a000 data=0x7ff570dc bss=0x7ff57630
[*06/28/2017 00:00:14.2431] Module: nfnetlink_log .text=0x7ff66000 data=0x7ff67600 bss=0x7ff6780c
[*06/28/2017 00:00:14.2431] Module: xt_mark .text=0x7ff6d000 data= bss=
[*06/28/2017 00:00:14.2431] Module: xt_policy .text=0x7ff71000 data= bss=
[*06/28/2017 00:00:14.2431] Module: ebtables .text=0x7ff75000 data=0x7ff785ec bss=
[*06/28/2017 00:00:14.2431] Module: ebt_ip .text=0x7ff7c000 data= bss=
[*06/28/2017 00:00:14.2431] Module: ebt_ip6 .text=0x7ff80000 data= bss=
[*06/28/2017 00:00:14.2431] Module: ipt_ULOG .text=0x7ff84000 data=0x7ff848a0 bss=
[*06/28/2017 00:00:14.2431] Module: crc_itu_t .text=0x7ff88000 data= bss=
[*06/28/2017 00:00:14.2431] Module: lowmemorykiller .text=0x7ff8c000 data=0x7ff8c2f4 bss=0x7ff8c4a0
[*06/28/2017 00:00:14.2432] Module: p8022 .text=0x7ff90000 data= bss=
[*06/28/2017 00:00:14.2432] Module: psnap .text=0x7ff94000 data=0x7ff94344 bss=0x7ff944c4
[*06/28/2017 00:00:14.2432] Module: rng_core .text=0x7ff98000 data=0x7ff98818 bss=0x7ff989d8
[*06/28/2017 00:00:14.2432] Module: udf .text=0x7ff9c000 data=0x7ffac098 bss=0x7ffac214
[*06/28/2017 00:00:14.2685]
[*06/28/2017 00:00:14.2685] led patteren module start
[*06/28/2017 00:00:14.2948] milos /tmp/SC4_1dbm.txt
[*06/28/2017 00:00:14.4023] Last reload reason : 0: unknown
[*06/28/2017 00:00:15.2851] set led_patteren 12
[*06/28/2017 00:00:16.3860] set led_patteren 4
[*06/28/2017 00:00:22.3745] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*06/28/2017 00:00:22.3860] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:00:22.3865] ip6_port srcr6, ip6local fe80::a223:9fff:fefa:628, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaac)
[*06/28/2017 00:00:36.9164] Create symlink /dev/mic_cert result 0
[*06/28/2017 00:00:36.9164] Loading certificates from storage...
[*06/28/2017 00:00:36.9301] SKU to radio FW
[*06/28/2017 00:00:37.2273] Generating key, this may take a while...
[*06/28/2017 00:00:43.9430] Public key portion is:
[*06/28/2017 00:00:43.9430] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDNqF9qbdwU5eDSeiNwp1+x0zmwYWOJISkBfvTFzlWkow5AfkrXIqWRjSecF6xaGM2BsExs6QbyEBQAzJuVhfaRLnyCBSMuiL9dhZnYr4iH/pQeqb7zSeYS7kNdBcXbCSVtxjYHDbWHBVRUEt8Yj2qIYbS/QJLYJOBb+ov2ADZDAcNyGI5XWIxaLPjNTJkA+KKAeuYQ0/ijVuZiVm1W7OnX5+s2H9ocmLPpxG9ZVgalxl1n/VSegJf1ZdiAxJp5ckQuHalqVzKnw+MezxVsm1x9ajz+EDNZC57N2dfjx6AgSs68ah2nI5qP0u696OoFZS8VhMuiUqLg+YH4h/f4kJWL root@mA0239FFA0628
[*06/28/2017 00:00:43.9430] Fingerprint: md5 cb:91:34:01:9f:c0:24:24:df:d6:44:b5:ac:1d:06:f8
[*06/28/2017 00:00:47.3262] starting tam services using ACT2...
[*06/28/2017 00:00:47.6773] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_XOR_5G_FILE__/\/radio_fw\/X5.csv/g' -e 's/__EVM_POWER_XOR_5G_FILE__/\/radio_fw\/EVM_X5.csv/g' -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAIN_5G__/47/g' -e 's/__PRODUCT_ID__/AIR-AP1562I-D-K9/g' -e 's/__AP_TYPE__/68/g' -e 's/__WIRELESS_MAC__/40:01:7A:99:87:20/g' -e 's/__WIRED_MAC__/A0:23:9F:FA:06:28/g' -e 's/__WIRED1_MAC__/A0:23:9F:FA:06:28/g' | DMALLOC_OPTIONS=debug=0x03,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*06/28/2017 00:00:47.7883] Password for 'Cisco' changed
[*06/28/2017 00:00:49.6126] Stopped Radio 1
[*06/28/2017 00:00:49.6250] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:49.8683]
[*06/28/2017 00:00:49.8683] BLE initialized on Board PID AIR-AP1562I-D-K9, AP type 44
[*06/28/2017 00:00:49.8686] CRIT-MeshControl:
[*06/28/2017 00:00:49.8686] Mesh Control: skipped adding wired1 backhaul
[*06/28/2017 00:00:50.1139] Stopped Radio 0
[*06/28/2017 00:00:50.1263] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:00:50.8018] DOT11_CFG[0] Radio Mode is changed from Local to Bridge
[*06/28/2017 00:00:50.8023] DOT11_CFG[1] Radio Mode is changed from Local to Bridge
[*06/28/2017 00:00:51.0684] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:51.3817] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:51.3912] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:51.8454] Radio0 not started, not enough POE power
[*06/28/2017 00:00:51.8485] bftype is 6
[*06/28/2017 00:00:51.8581] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:52.1680] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:52.4841] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:52.8075] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:52.8170] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:53.2458] Radio1 not started, not enough POE power
[*06/28/2017 00:00:53.2489] bftype is 6
[*06/28/2017 00:00:53.2586] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:53.2980] CRIT-MeshControl: Starting Mesh
[*06/28/2017 00:00:53.3083] CRIT-MeshWiredBackhaul[0]: Set as uplink
[*06/28/2017 00:00:53.3083] CRIT-MeshWiredAdj[0][A0:23:9F:FA:06:28]: Set as Parent(new)
[*06/28/2017 00:00:53.3154] Stopped Radio 0
[*06/28/2017 00:00:53.3188] Radio0 not started, not enough POE power
[*06/28/2017 00:00:53.3250] Stopped Radio 1
[*06/28/2017 00:00:53.3283] Radio1 not started, not enough POE power
[*06/28/2017 00:00:53.3284] CRIT-MeshLink: Set Root port Mac: A0:23:9F:FA:06:28 BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*06/28/2017 00:00:53.3288] CRIT-MeshLink: Notify Capwap Link Up: mac: A0:23:9F:FA:06:28 BH Id: 0 GW_reachable: No Roam: false
[*06/28/2017 00:00:53.5716] driver_wpas: - wpa_driver_wpas_init
[*06/28/2017 00:00:57.2988] waiting for POE negotiation to complete
[*06/28/2017 00:01:02.2992] waiting for POE negotiation to complete
[*06/28/2017 00:01:07.2996] waiting for POE negotiation to complete
[*06/28/2017 00:01:07.2997]
[*06/28/2017 00:01:12.3001] waiting for POE negotiation to complete
[*06/28/2017 00:01:17.3006] waiting for POE negotiation to complete
[*06/28/2017 00:01:22.3010] waiting for POE negotiation to complete
[*06/28/2017 00:01:27.3014] waiting for POE negotiation to complete
[*06/28/2017 00:01:27.3015]
[*06/28/2017 00:01:32.3019] waiting for POE negotiation to complete
[*06/28/2017 00:01:37.3023] waiting for POE negotiation to complete
[*06/28/2017 00:01:42.3028] waiting for POE negotiation to complete
[*06/28/2017 00:01:47.3032] waiting for POE negotiation to complete
[*06/28/2017 00:01:52.3037] waiting for POE negotiation to complete
[*06/28/2017 00:01:54.9684] Stopped Radio 0
[*06/28/2017 00:01:54.9996] Stopped Radio 1
[*06/28/2017 00:01:55.0037] SYS-COND: Bringing down radio wifi0
[*06/28/2017 00:01:55.0037] SYS-COND: Bringing down radio wifi1
[*06/28/2017 00:01:55.0037] SYS-COND: AP is in critical condition
[*06/28/2017 00:02:10.3090] Resetting wired0 and[06/28/2017 00:02:10.3300] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
srcr6, ifconfig[06/28/2017 00:02:10.4500] wired0: stopped
down up
[*06/28/2017 00:02:10.3091]
[*06/28/2017 00:02:10.5223] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:02:12.5300] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:02:12.6300] wired0 emac 1: link up
[06/28/2017 00:02:12.6800] wired0: link up
[06/28/2017 00:02:12.7300] wired0: started
[*06/28/2017 00:02:12.7889] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:02:12.7905] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:02:27.7953] Resetting wired0 and[06/28/2017 00:02:27.8200] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
srcr6, ifconfig[06/28/2017 00:02:27.9400] wired0: stopped
down up
[*06/28/2017 00:02:28.0103] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:02:30.0200] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:02:30.1200] wired0 emac 1: link up
[06/28/2017 00:02:30.1700] wired0: link up
[06/28/2017 00:02:30.2200] wired0: started
[*06/28/2017 00:02:30.2770] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:02:30.2786] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:02:45.2840] Resetting wired0 and[06/28/2017 00:02:45.3100] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
srcr6, ifconfig[06/28/2017 00:02:45.4200] wired0: stopped
down up
[*06/28/2017 00:02:45.4973] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:02:47.5100] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:02:47.6100] wired0 emac 1: link up
[06/28/2017 00:02:47.6600] wired0: link up
[06/28/2017 00:02:47.7100] wired0: started
[*06/28/2017 00:02:47.7639] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:02:47.7654] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:02:53.3084] CRIT-MeshWiredAdj[0][A0:23:9F:FA:06:28]: Remove as Parent
[*06/28/2017 00:02:53.3085] CRIT-MeshLink: Link Down Block Root port Mac: A0:23:9F:FA:06:28 BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*06/28/2017 00:02:53.3086] CRIT-MeshWiredBackhaul[0]: Remove as uplink
[*06/28/2017 00:02:53.3150] Stopped Radio 0
[*06/28/2017 00:02:53.3183] Radio0 not started, not enough POE power
[*06/28/2017 00:02:53.3246] Stopped Radio 1
[*06/28/2017 00:02:53.3277] Radio1 not started, not enough POE power
[*06/28/2017 00:02:55.3347] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:02:55.3824] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:02:57.3822] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:02:57.4299] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:02:59.4297] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:02:59.4800] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:01.4798] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:03:01.5274] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:03.5271] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:03:03.5746] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:05.5743] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:03:05.6217] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:07.6216] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:03:07.6691] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:09.6689] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:03:09.7164] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:11.7161] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:03:11.7685] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:13.7670] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:03:13.8159] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:15.8157] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:03:15.8631] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:17.8629] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:03:17.9117] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:19.9114] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:03:19.9589] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:21.9589] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:03:22.0155] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:24.0153] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:03:24.0655] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:26.0625] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:03:26.1101] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:28.1099] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:03:28.1575] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:30.1573] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:03:30.2047] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:32.2046] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:03:32.2521] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:34.2519] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:03:34.2994] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:36.2991] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:03:36.3501] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:38.3472] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:03:38.3948] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:40.3946] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:03:40.4422] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:42.4420] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:03:42.4895] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:44.4893] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:03:44.5367] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:46.5367] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:03:46.5872] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:48.5870] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:03:48.6344] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:50.6341] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:03:50.6820] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:03:52.6818] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:03:52.7293] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:03:54.7291] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:03:54.7764] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:03:56.7763] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:03:56.8250] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:03:58.8248] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:03:58.8723] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:00.8721] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:04:00.9196] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:02.9194] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:04:02.9668] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:04.9666] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:04:05.0141] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:07.0139] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:04:07.0614] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:09.0612] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:04:09.1088] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:11.1086] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:04:11.1561] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:13.1559] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:04:13.2035] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:15.2060] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:04:15.2536] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:17.2534] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:04:17.3009] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:19.3007] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:04:19.3483] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:21.3480] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:04:21.3955] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:23.3954] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:04:23.4429] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:25.4427] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:04:25.4915] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:27.4912] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:04:27.5417] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:29.5421] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:04:29.5909] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:31.5907] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:04:31.6382] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:33.6380] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:04:33.6859] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:35.6857] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:04:35.7332] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:37.7330] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:04:37.7825] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:39.7823] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:04:39.8339] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:41.8337] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:04:41.8811] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:43.8809] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:04:43.9290] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:45.9289] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:04:45.9763] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:47.9762] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:04:48.0237] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:50.0234] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:04:50.0709] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:04:52.0707] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:04:52.1211] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:04:54.1209] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:04:54.1683] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:04:56.1681] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:04:56.2155] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:04:58.2153] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:04:58.2628] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:05:00.2626] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:05:00.3101] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:05:02.3099] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:05:02.3574] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:05:04.3571] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:05:04.4045] DOT11_DRV[1]: set_channel Channel set to 149
�þ@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ÿ@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c2960x-universalk9-mz.152-2.E6/c2960x-universalk9-mz.152-2.E6.bin" uncompressed and installed, entry point: 0x3000
executing...
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
cisco Systems, Inc.
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 16-Dec-16 21:27 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 834560
mifs[7]: Bytes available : 971776
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 1 seconds.
mifs[10]: Initialization complete.
mifs[11]: 652 files, 20 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 27138048
mifs[11]: Bytes available : 95047680
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
Software version is different so extracting
the whole bundle
Waiting for Stack Master Election...
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
export@cisco.com.
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision V01) with 524288K bytes of memory.
Processor board ID JIN2140101H
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : EC:1D:8B:38:CB:00
Motherboard assembly number : 73-16694-06
Power supply part number : 341-0528-02
Motherboard serial number : JPI213903WK
Power supply serial number : DCC211092V8
Model revision number : V01
Motherboard revision number : B0
Model number : WS-C2960X-24PS-IN
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : JPI213902CJ
System serial number : JIN2140101H
Top Assembly Part Number : 68-101211-01
Top Assembly Revision Number : C0
Version ID : V01
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24PS-L 15.2(2)E6 C2960X-UNIVERSALK9-M
Press RETURN to get started!
*Mar 1 00:00:27.661: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.153: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Mar 27 11:09:11.121: in Switch 0. Cannot read pid from Flexstack module
Mar 27 11:09:11.219: %HPAA:hpaa_port_bitmap_init:254:n_ports = 28, sizeof (**hpaa_port_bitmap.bitlist_array) = 16
Mar 27 11:09:47.409: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
Mar 27 11:09:48.748: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Mar 27 11:09:48.748: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Mar 27 11:09:50.590: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Mar 27 11:09:54.585: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan201, changed state to down
Mar 27 11:09:54.655: %SYS-5-CONFIG_I: Configured from memory by console
Mar 27 11:09:54.728: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Mar 27 11:09:54.728: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
Mar 27 11:09:54.728: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
Mar 27 11:09:55.060: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Mar 27 11:09:55.113: %SYS-5-RESTART: System restarted --
Mar 27 11:09:56.493: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down
Mar 27 11:09:56.570: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
Mar 27 11:09:56.658: %ILPOWER-7-DETECT: Interface Gi1/0/2: Power Device detected: IEEE PD
Mar 27 11:09:57.455: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/2: Power granted
Mar 27 11:09:57.496: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Mar 27 11:09:58.507: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.% Generating 1024 bit RSA keys, keys will be non-exportable...
Mar 27 11:10:09.213: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to up
Mar 27 11:10:10.216: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
[OK] (elapsed time was 3 seconds)
[OK]
Mar 27 11:10:13.264: %SSH-5-ENABLED: SSH 1.99 has been enabled
Mar 27 11:10:13.344: %PKI-6-AUTOSAVE: Running configuration saved to NVRAM
Mar 27 11:10:37.220: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan201, changed state to up[*06/28/2017 00:00:36.9704] Create symlink /dev/mic_cert result 0
[*06/28/2017 00:00:36.9704] Loading certificates from storage...
[*06/28/2017 00:00:36.9841] SKU to radio FW
[*06/28/2017 00:00:37.2816] Generating key, this may take a while...
[*06/28/2017 00:00:37.5441] Public key portion is:
[*06/28/2017 00:00:37.5441] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCsGxZjG5MrViKJAVwQoa3XpFfPR694NN9o1N2621cjjvJq+3BHE4jvZwrM29H4K5iSsU/bkwFM56W1N1ITuieXG0YDVq/XqPx+NC7y/1AqjLCd9Kojy4Oc78q1kYAQURiaQZgw/Nbri9DAtQpFI5jfA+amo1BvNFxxBlwBhTmr6bNmW9R5RVEP8OvBhNc2eSHm5+zDr+zbm60psPH7tLRKIyOfMYNDhdL7G0MiP9eW1v4983aZsiHufRuoMRjNF0dTjlXlymvBANfpk5QB233fD4eBDpX+HQPVCgM4ZgTeDh+TqvEP7Jeg/tG+97ckicdtc/BtQFyChueLhzZuz0sX root@mA0239FFA0628
[*06/28/2017 00:00:37.5441] Fingerprint: md5 4e:9e:3e:ce:b7:46:31:c2:9b:55:70:4f:25:41:c6:14
[*06/28/2017 00:00:40.9335] starting tam services using ACT2...
[*06/28/2017 00:00:41.2831] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_XOR_5G_FILE__/\/radio_fw\/X5.csv/g' -e 's/__EVM_POWER_XOR_5G_FILE__/\/radio_fw\/EVM_X5.csv/g' -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAIN_5G__/47/g' -e 's/__PRODUCT_ID__/AIR-AP1562I-D-K9/g' -e 's/__AP_TYPE__/68/g' -e 's/__WIRELESS_MAC__/40:01:7A:99:87:20/g' -e 's/__WIRED_MAC__/A0:23:9F:FA:06:28/g' -e 's/__WIRED1_MAC__/A0:23:9F:FA:06:28/g' | DMALLOC_OPTIONS=debug=0x03,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*06/28/2017 00:00:41.3921] Password for 'Cisco' changed
[*06/28/2017 00:00:43.0980] Stopped Radio 0
[*06/28/2017 00:00:43.1104] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:00:43.3502] CRIT-MeshControl:
[*06/28/2017 00:00:43.3502] Mesh Control: skipped adding wired1 backhaul
[*06/28/2017 00:00:43.3505]
[*06/28/2017 00:00:43.3505] BLE initialized on Board PID AIR-AP1562I-D-K9, AP type 44
[*06/28/2017 00:00:43.6717] Stopped Radio 1
[*06/28/2017 00:00:43.6841] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:43.9302] DOT11_CFG[0] Radio Mode is changed from Local to Bridge
[*06/28/2017 00:00:43.9308] DOT11_CFG[1] Radio Mode is changed from Local to Bridge
[*06/28/2017 00:00:44.1965] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:44.5082] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:44.5178] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:44.9733] Radio0 not started, not enough POE power
[*06/28/2017 00:00:44.9763] bftype is 6
[*06/28/2017 00:00:44.9861] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:00:45.2944] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:45.6121] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:45.9330] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:45.9426] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:46.3719] Radio1 not started, not enough POE power
[*06/28/2017 00:00:46.3751] bftype is 6
[*06/28/2017 00:00:46.3848] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:00:46.4242] CRIT-MeshControl: Starting Mesh
[*06/28/2017 00:00:46.4344] CRIT-MeshWiredBackhaul[0]: Set as uplink
[*06/28/2017 00:00:46.4345] CRIT-MeshWiredAdj[0][A0:23:9F:FA:06:28]: Set as Parent(new)
[*06/28/2017 00:00:46.4415] Stopped Radio 0
[*06/28/2017 00:00:46.4450] Radio0 not started, not enough POE power
[*06/28/2017 00:00:46.4512] Stopped Radio 1
[*06/28/2017 00:00:46.4545] Radio1 not started, not enough POE power
[*06/28/2017 00:00:46.4546] CRIT-MeshLink: Set Root port Mac: A0:23:9F:FA:06:28 BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*06/28/2017 00:00:46.4550] CRIT-MeshLink: Notify Capwap Link Up: mac: A0:23:9F:FA:06:28 BH Id: 0 GW_reachable: No Roam: false
[*06/28/2017 00:00:46.6981] driver_wpas: - wpa_driver_wpas_init
[*06/28/2017 00:00:50.4250] waiting for POE negotiation to complete
[*06/28/2017 00:00:55.4254] waiting for POE negotiation to complete
[*06/28/2017 00:00:55.4255]
[*06/28/2017 00:01:00.4259] waiting for POE negotiation to complete
[*06/28/2017 00:01:05.4264] waiting for POE negotiation to complete
[*06/28/2017 00:01:10.4268] waiting for POE negotiation to complete
[*06/28/2017 00:01:10.4269]
[*06/28/2017 00:01:15.4273] waiting for POE negotiation to complete
[*06/28/2017 00:01:16.9669] SYS-COND: Set radio wifi0 power 6 antenna chain 2 of 3
[*06/28/2017 00:01:16.9669] SYS-COND: Set radio wifi1 power 6 antenna chain 2 of 3
[*06/28/2017 00:01:16.9669] SYS-COND: AP is in fair condition
[*06/28/2017 00:01:32.4327] Rese[06/28/2017 00:01:32.4400] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
tting wired0 and srcr6, ifconfig[06/28/2017 00:01:32.5700] wired0: stopped
down up
[*06/28/2017 00:01:32.6460] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:01:34.6600] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:01:34.7600] wired0 emac 1: link up
[06/28/2017 00:01:34.8200] wired0: link up
[06/28/2017 00:01:34.8600] wired0: started
[*06/28/2017 00:01:34.9125] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:01:34.9144] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:01:49.9191] Resetting wired0 and[06/28/2017 00:01:49.9500] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
srcr6, ifconfig[06/28/2017 00:01:50.0600] wired0: stopped
down up
[*06/28/2017 00:01:50.1323] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:01:52.1500] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:01:52.2500] wired0 emac 1: link up
[06/28/2017 00:01:52.3000] wired0: link up
[06/28/2017 00:01:52.3500] wired0: started
[*06/28/2017 00:01:52.3990] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:01:52.4006] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:02:07.4060] Resetting wired0 and[06/28/2017 00:02:07.4300] NSS Long pool #16: buf_size=2880 - free 22480 of 22480 buffers
srcr6, ifconfig[06/28/2017 00:02:07.5500] wired0: stopped
down up
[*06/28/2017 00:02:07.4061]
[*06/28/2017 00:02:07.6208] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:02:09.6300] NSS Long pool #16: buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:02:09.7300] wired0 emac 1: link up
[06/28/2017 00:02:09.7900] wired0: link up
[06/28/2017 00:02:09.8300] wired0: started
[*06/28/2017 00:02:09.8873] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:02:09.8889] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:14:18.4363] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:14:18.4836] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:14:20.4839] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:14:20.5342] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:14:22.5340] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:14:22.5811] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:14:24.5810] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:14:24.6281] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:14:26.6279] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:14:26.6800] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:14:28.6784] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:14:28.7256] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:14:30.7254] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:14:30.7725] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:14:32.7724] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:14:32.8226] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:14:34.8225] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:14:34.8696] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:14:36.8694] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:14:36.9165] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:14:38.9164] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:14:38.9637] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:14:40.9634] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:14:41.0105] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:14:43.0104] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:14:43.0576] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:14:45.0574] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:14:45.1046] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:14:47.1043] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:14:47.1515] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:14:48.1820] CRIT-MeshControl: Could not select an uplink for last 5 minutes. Restarting backhauls
[*06/28/2017 00:14:48.1821] CRIT-MeshControl: Stopping Mesh
[*06/28/2017 00:14:48.1886] Stopped Radio 0
[*06/28/2017 00:14:48.1917] Radio0 not started, not enough POE power
[*06/28/2017 00:14:48.1981] Stopped Radio 1
[*06/28/2017 00:14:48.2012] Radio1 not started, not enough POE power
[*06/28/2017 00:14:48.2526] CRIT-MeshControl: Starting Mesh
[*06/28/2017 00:14:48.2608] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:14:48.3081] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:14:48.3274] CRIT-MeshWiredBackhaul[0]: Set as uplink
[*06/28/2017 00:14:48.3275] CRIT-MeshWiredAdj[0][A0:23:9F:FA:06:1E]: Set as Parent(new)
[*06/28/2017 00:14:48.3339] Stopped Radio 0
[*06/28/2017 00:14:48.3370] Radio0 not started, not enough POE power
[*06/28/2017 00:14:48.3434] Stopped Radio 1
[*06/28/2017 00:14:48.3465] Radio1 not started, not enough POE power
[*06/28/2017 00:14:48.3466] CRIT-MeshLink: Set Root port Mac: A0:23:9F:FA:06:1E BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*06/28/2017 00:14:48.3469] CRIT-MeshLink: Notify Capwap Link Up: mac: A0:23:9F:FA:06:1E BH Id: 0 GW_reachable: No Roam: false
[*06/28/2017 00:14:48.5325] driver_wpas:  - wpa_driver_wpas_init
[*06/28/2017 00:15:03.0565] Resetting wired0 and[06/28/2017 00:15:03.0800] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
 srcr6, ifconfig[06/28/2017 00:15:03.2000] wired0: stopped
 down up
[*06/28/2017 00:15:03.2714] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:15:05.2800] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:15:05.3800] wired0 emac 1: link up
[06/28/2017 00:15:05.4400] wired0: link up
[06/28/2017 00:15:05.4800] wired0: started
[*06/28/2017 00:15:05.5380] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:15:05.5396] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:15:20.5444] Resetting wired0 and[06/28/2017 00:15:20.5700] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
 srcr6, ifconfig[06/28/2017 00:15:20.6900] wired0: stopped
 down up
[*06/28/2017 00:15:20.7593] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:15:22.7700] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:15:22.8700] wired0 emac 1: link up
[06/28/2017 00:15:22.9300] wired0: link up
[06/28/2017 00:15:22.9700] wired0: started
[*06/28/2017 00:15:23.0259] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:15:23.0275] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:15:38.0322] Resetting wired0 and[06/28/2017 00:15:38.0600] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
 srcr6, ifconfig[06/28/2017 00:15:38.1800] wired0: stopped
 down up
[*06/28/2017 00:15:38.2471] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:15:40.2600] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:15:40.3600] wired0 emac 1: link up
[06/28/2017 00:15:40.4200] wired0: link up
[06/28/2017 00:15:40.4600] wired0: started
[*06/28/2017 00:15:40.5138] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:15:40.5153] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:15:55.5200] Rese[06/28/2017 00:15:55.5300] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
tting wired0 and srcr6, ifconfig[06/28/2017 00:15:55.6600] wired0: stopped
 down up
[*06/28/2017 00:15:55.7333] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:15:57.7500] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:15:57.8500] wired0 emac 1: link up
[06/28/2017 00:15:57.9000] wired0: link up
[06/28/2017 00:15:57.9500] wired0: started
[*06/28/2017 00:15:58.0001] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:15:58.0020] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:16:13.0074] Resetting wired0 and[06/28/2017 00:16:13.0300] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
 srcr6, ifconfig[06/28/2017 00:16:13.1500] wired0: stopped
 down up
[*06/28/2017 00:16:13.2222] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:16:15.2400] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:16:15.3400] wired0 emac 1: link up
[06/28/2017 00:16:15.3900] wired0: link up
[06/28/2017 00:16:15.4300] wired0: started
[*06/28/2017 00:16:15.4889] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:16:15.4905] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:16:30.4952] Resetting wired0 and[06/28/2017 00:16:30.5200] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
 srcr6, ifconfig[06/28/2017 00:16:30.6400] wired0: stopped
 down up
[*06/28/2017 00:16:30.7084] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[06/28/2017 00:16:32.7200] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:16:32.8200] wired0 emac 1: link up
[06/28/2017 00:16:32.8700] wired0: link up
[06/28/2017 00:16:32.9200] wired0: started
[*06/28/2017 00:16:32.9749] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:16:32.9768] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:16:47.9823] Resetting wired0 and[06/28/2017 00:16:48.0100] NSS Long    pool #16:  buf_size=2880 - free 22480 of 22480 buffers
 srcr6, ifconfig[06/28/2017 00:16:48.1300] wired0: stopped
 down up
[*06/28/2017 00:16:48.1976] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*06/28/2017 00:16:48.3276] CRIT-MeshWiredAdj[0][A0:23:9F:FA:06:1E]: Remove as Parent
[*06/28/2017 00:16:48.3277] CRIT-MeshLink: Link Down Block Root port Mac: A0:23:9F:FA:06:1E BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*06/28/2017 00:16:48.3278] CRIT-MeshWiredBackhaul[0]: Remove as uplink
[*06/28/2017 00:16:48.3344] Stopped Radio 0
[*06/28/2017 00:16:48.3375] Radio0 not started, not enough POE power
[*06/28/2017 00:16:48.3439] Stopped Radio 1
[*06/28/2017 00:16:48.3471] Radio1 not started, not enough POE power
[06/28/2017 00:16:50.2100] NSS Long    pool #16:  buf_size=2880 - 22480 of 22480 buffers added
[06/28/2017 00:16:50.3100] wired0 emac 1: link up
[06/28/2017 00:16:50.3700] wired0: link up
[06/28/2017 00:16:50.4100] wired0: started
[*06/28/2017 00:16:50.4643] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*06/28/2017 00:16:50.4660] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*06/28/2017 00:16:50.4710] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:16:50.5186] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:16:52.5185] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:16:52.5658] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:16:54.5656] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:16:54.6131] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:16:56.6130] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:16:56.6603] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:16:58.6602] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:16:58.7074] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:17:00.7100] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:17:00.7573] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:17:02.7571] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:17:02.8046] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:17:04.8045] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:17:04.8517] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:17:06.8515] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:17:06.8988] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:17:08.8987] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:17:08.9460] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:17:10.9458] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:17:10.9940] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:17:12.9938] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:17:13.0442] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:17:15.0439] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:17:15.0913] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:17:17.0910] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:17:17.1383] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:17:19.1381] DOT11_DRV[0]: set_channel Channel set to 5
[*06/28/2017 00:17:19.1854] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:17:21.1853] DOT11_DRV[0]: set_channel Channel set to 6
[*06/28/2017 00:17:21.2337] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:17:23.2338] DOT11_DRV[0]: set_channel Channel set to 7
[*06/28/2017 00:17:23.2811] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:17:25.2809] DOT11_DRV[0]: set_channel Channel set to 8
[*06/28/2017 00:17:25.3311] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:17:27.3309] DOT11_DRV[0]: set_channel Channel set to 9
[*06/28/2017 00:17:27.3784] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:17:29.3783] DOT11_DRV[0]: set_channel Channel set to 10
[*06/28/2017 00:17:29.4256] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:17:31.4254] DOT11_DRV[0]: set_channel Channel set to 11
[*06/28/2017 00:17:31.4728] DOT11_DRV[1]: set_channel Channel set to 153
[*06/28/2017 00:17:33.4727] DOT11_DRV[0]: set_channel Channel set to 1
[*06/28/2017 00:17:33.5201] DOT11_DRV[1]: set_channel Channel set to 157
[*06/28/2017 00:17:35.5199] DOT11_DRV[0]: set_channel Channel set to 2
[*06/28/2017 00:17:35.5671] DOT11_DRV[1]: set_channel Channel set to 161
[*06/28/2017 00:17:37.5670] DOT11_DRV[0]: set_channel Channel set to 3
[*06/28/2017 00:17:37.6172] DOT11_DRV[1]: set_channel Channel set to 149
[*06/28/2017 00:17:39.6170] DOT11_DRV[0]: set_channel Channel set to 4
[*06/28/2017 00:17:39.6645] DOT11_DRV[1]: set_channel Channel set to 153
7 Replies 7
Leo Laohoo
Is the AP meant to be configured as a MESH AP?
[*06/28/2017 00:16:48.3375] Radio0 not started, not enough POE power to 149
Exactly how are you powering up the AP?
I have just power it on. After then I am getting the below provided information..
Not sure about this:
My it sounds a little as if it's out of free space.
Can you check with the dir command?
Issue was with console cable..
Now I am able to put IP address etc but AP is not registering to WLC..
WLC rejecting it..
Upgraded WLC to 8.5.120 version but no luck
please post the AP log from booting and joining process.
