AP AIR-CAP702W can't join cisco WLC 2504
Solanin19
Hello everyone,
My 3 air-ap1815w-E can join the wlc 2504 controller without problem, but not my air-CAP702W.
the log from the CAP702W:
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
Not in Bound state.
*Mar  1 01:01:35.459: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 01:01:45.575: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.15.105, mask 255.255.255.0, hostname APf0b2.e5c4.6610
wlc interface for the AP management : 192.168.15.254
dhcp pool: 192.168.15.0
So the ap can get an ip from the pool, and can ping the correct interface but can not discover it.
My guess is that the version on my WLC (8.5.131.0) can not support the cap702w-E (https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html)
If i am correct i have to change every CAP702W-E by a AP1815 or is there an another solution ?
this is really strange. check the time on WLC again. as a last resort its better to move with cisco TAC
Good luck
KB
21 Replies 21
according to compatibility sheet (https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.pdf) 700 series supports with 8.5.131.0 after 15.3(3)JF7 AP OS. as i see you have autonomous ready Hardware SKU AP (AIR-CAP702W). in this case check the OS type is autonomous or LWAPP. you need LWAPP (https://software.cisco.com/download/home/286250957/type/280775090/release/15.3.3-JI1) OS to join with WLC. in that case you may need to reimage AP with LWAPP OS.
good luck
Good luck
KB
the air-cap702w seems already with the lwapp os type:
Cisco IOS Software, C702 Software (ap1g1-RCVK9W8-M), Version 15.3(3)JBB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 04-May-15 15:20 by prod_rel_team
ROM: Bootstrap program is C702 boot loader
BOOTLDR: C702 Boot Loader (ap1g1-BOOT-M) Version 15.2(4)JB5m, RELEASE SOFTWARE (fc2)
APf0b2.e5c4.6610 uptime is 4 hours, 11 minutes
System image file is "flash:/ap1g1-rcvk9w8-mx/ap1g1-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-CAP702W-E-K9 (MIPS74k) processor (revision 02) with 86016K/45056K bytes of memory.
Processor board ID KWC192701IR
MIPS74k CPU at 560Mhz, revision number 0x0000
Last reset from power-on
LWAPP image version 8.1.102.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:B2:E5:C4:66:10
Part Number                          : 74-12289-02
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : KWC192701IR
Top Assembly Part Number             : 000-00000-00
Top Assembly Serial Number           : KWC192701IR
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP702W-E-K9
Configuration register is 0xF
can you try with LWAPP recovery image in download section?
Good luck
KB
i tried the recovery cisco image as you suggested
APf0b2.e5c4.6610#show version
Cisco IOS Software, C702 Software (ap1g1-RCVK9W8-M), Version 15.3(3)JI1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 17-Aug-18 00:01 by prod_rel_team
APf0b2.e5c4.6610 uptime is 3 minutes
Last reload reason:
 --More--
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.25agree to comply with applicable laws and regulations. If you are unable
LWAPP image version 8.8.100.0
Same result:
Mar  1 00:01:07.831: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.15.197, mask 255.255.255.0, hostname APf0b2.e5c4.6610
*Mar  1 00:01:28.299: %CDP_PD-4-POWER_OK: Full power - INJECTOR_CONFIGURED_ON_SOURCE inline power source
Not in Bound state.
*Mar  1 00:02:08.191: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:02:18.315: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.15.198, mask 255.255.255.0, hostname APf0b2.e5c4.6610
can you try setting WLC map manually in AP. also use LWAPP image for this. not the recovery.
command - "capwap ap controller ip address <ip_address>"
Good luck
KB
I have tried the image recovery and the manual configuration for wlc on the ap nothing changed.
Can you send small diagram of your setup? With device models. Also can you grt debug of wlc?
Good luck
KB
I join the schema and the log
I joined the log and the schema.
how about the WLC debug at same time?
Good luck
KB
sorry i seen it later
Good luck
KB
what is the OS version of wlc
Good luck
KB
8.5.131.0
