AP connectivity in SDA
riah
Migrating the switch in IDF to SDA , I have a question related to the AP connection to the Embedded WC at the BN.It has always been a problem to see the AP's back in the DNAC. Before that the AP's are connected to the standalone WLC 5500.
My question is
1. what the best practice is to make the SDA migration smooth.
Thank you.
ammahend
look at Cisco live on demand library, there are some good presentations, Jerome Dolphin has a few good one specifically on migration best practices.
-hope this helps-
balaji.bandi
is this Fabric Wireless or OTT ?
if SD-Access - AP will be Iused nfra VN
Look at SD-Access Wireless deployment guide :
https://www.cisco.com/c/dam/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/deploy-guide/cisco-dna-center-sd-access-wl-dg.pdf
BB
riah
It's OTT we are using 5500.Although after following the process in the documentation , it takes quiet a while for the AP to connect (show up on border node)
if you using OTT  - Only required AP to reachable to WLC using IP ?
what AP Models, what Code running on 5500 ?
BB
