AP High Availability not working for some APS
Michele Toblini
Level 2
Level 2
Hi guys,
we have 3 WLC 5520 in 8.5.140.0 and i had to reboot all of them to get rid of new mobility. In every AP it is configured manually the failover of the APs.
When i rebooted WLC-3 almost all the APs joined the second one as it was supposed to. Just few of them joined WLC-1. I tried to reboot few of them but they were stuck in the WLC-1. I've also resetted the configuration but nothing happend. I thought, okay, let's reboot the WLC-1 so they will be forced to join again the WLC-3 as it was before.
Nothing, all the AP belonging the WLC-1did the failover except those stubborn that now are stuck in one controller.
Here are the models of APs:
AIR-AP2802E-E-K9
1 AIR-CAP1602I-E-K9
AIR-AP1562I-E-K9
Any clue about what is going on?
Michele
7 Replies 7
Scott Fella
Make sure that the high availability you defined on each ap is correct. The controller host name is case sensitive. Check your license and old config also just In case something happened during the reboot.
-Scott
the licences are not a problem, all controllers are able to take all APs. Also the host name is correct.
Grendizer
Try to check on one of the faulty APs the below: (From AP cli)
#show run | i controller
If you see the name is wrong for the primary WLC then do this from the WLC gui:
1) Deleting Secondary controller name and IP, then Apply.
2) Then, configure Primary and Secondary name and IP, then Apply.
already done without success
Leo Laohoo
Regulatory Domain?
Did you try rebooting the APs?
I'm thinking possibly a side effect of https://bst.cloudapps.cisco.com/bugsearch/bug/CSCve14291 lingering from before you upgraded to 8.5.140.0. (what did you upgrade from?)
'show ver' on the AP itself would show if it's still running old code which would confirm you're hitting CSCve14291. Ignore what version the WLC says the AP is running - it only shows what it *should* be running not what it *is* running.
[Yes the AP keeps running different code from WLC without any problems LOL - somebody accidentally created a key part of the 9800 ISSU feature on AireOS]
Only caveat is this bug is only supposed to affect COS APs so should not affect the 1602 which runs IOS!
While you were going round rebooting WLCs you should probably have thought to update to at least 8.5.161.0 at the same time to resolve a whole lot of other bugs and security vulnerabilities.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
i tried rebooting and resetting.
AP Running Image : 8.5.140.0
Primary Boot Image : 8.5.140.0
Backup Boot Image : 8.3.141.3
Also
show capwap client rcb
AdminState : ADMIN_ENABLED
OperationState : UP
SwVer : 8.5.140.0
No it's running the correct version (8.5.140.0).
