AP NOT Joined
antonioxud80
Good Evening,
I have a problem with a cisco 5508 controller, no ap are unable to connect.
*spamApTask2: Nov 27 18:14:50.099: 00:5f:86:1e:66:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 100, joined Aps =0
*spamApTask2: Nov 27 18:14:50.099: 00:5f:86:1e:66:e0 Primary Discovery Response sent to 10.40.94.199:15203
*spamApTask6: Nov 27 18:14:50.249: c4:0a:cb:5c:7a:90 Primary Discovery Request from 10.40.94.114:48716
*spamApTask6: Nov 27 18:14:50.249: c4:0a:cb:5c:7a:90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 100, joined Aps =0
*spamApTask6: Nov 27 18:14:50.250: c4:0a:cb:5c:7a:90 Primary Discovery Response sent to 10.40.94.114:48716
*spamApTask6: Nov 27 18:14:50.250: c4:0a:cb:5c:7a:90 Primary Discovery Request from 10.40.94.114:48716
*spamApTask6: Nov 27 18:14:50.250: c4:0a:cb:5c:7a:90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 100, joined Aps =0
*spamApTask4: Nov 27 18:14:50.251: c4:0a:cb:2d:c3:d0 Primary Discovery Request from 10.40.94.59:1321
Do you have any suggestions?
many thanks
Regards Antonio
50 Replies 50
config ap lifetime-check mic enable
try this
Cisco Controller) config> ap lifetime-check mic enable
Incorrect usage. Use the '?' or <TAB> key to list commands.
(Cisco Controller) config>
not working
any update it seem work ?
do this command on WLC and see result.
config ap cert-expiry-ignore mic enable
or
Not sure why nobody seems to have mentioned it, but for anyone else reading this, the full info is in the field notice which addresses this problem - read through it slowly and carefully - twice for good measure.  It answers all the questions:
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
To fix it you must do the right things in the right order - time, software, config - and don't miss that it can affect both AP and WLC certs.
Some products which were too far out of support can't be fixed - only changing the time back to the past will keep them working.
Chosebin
Hello, I experienced this problem too but it was with some 1142 hw v1-v2-v3-v4 and 1242 hw v1-v2. I solved this by adding these commands to accept mic self-certificates, but too old due to hardware revision. Typed on CLI from the WLC, no reboot requiered.
config ap cert-expiry-ignore ssc enable
save config
