Bookmark
Subscribe
3336
AP not joining WLC
Majlo97
Hello to everyone,
I am basically just a beginner in networking, currently i am trying to join Cisco 3702 to joing WLC 2504
I have reseted it to rommon mode, uploaded rcvk image, it booted, after booting, it joined WLC, downloaded new image from WLC, when it rebooted after that, it cannot join WLC
Here is WLC output:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.120.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 15.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... Cisco_d7:05:35
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.0.0.5
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 3 days 1 hrs 34 mins 30 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... RS - Serbia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +30 C
External Temperature............................. +34 C
Fan Status....................................... 4664 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 15
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ D0:C2:82:D7:05:30
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Here is AP output:
APd072.dc2b.0dfc#show version
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JF5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 30-Jan-18 00:57 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
APd072.dc2b.0dfc uptime is 10 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JF5/ap3g2-k9w8-xx.153-3.JF5"
Last reload reason: Invalid config file.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702I-E-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCZ1811D0M4
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.5.120.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D0:72:DC:2B:0D:FC
Part Number : 73-15243-01
PCB Serial Number : FOC180827KX
Top Assembly Part Number : 068-05054-01
Top Assembly Serial Number : FCZ1811D0M4
Top Revision Number : A0
Product/Model Number : AIR-CAP3702I-E-K9
Configuration register is 0xF
APd072.dc2b.0dfc#show log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 163 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 165 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
Trap logging: level informational, 142 message lines logged
Logging to 255.255.255.255 (udp port 514, audit disabled,
link up),
120 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging Source-Interface: VRF Name:
Log Buffer (1048576 bytes):
*Mar 1 00:00:17.199: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:17.655: Registering HW DTLS
set_radio_pwr_mode: bad radio unit# 0
set_radio_pwr_mode: bad radio unit# 1
*Mar 1 00:00:18.675: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:18.679: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...APAVC Registering AVC licences on the AP to make sure we enable advanced PP
*Mar 1 00:00:20.011: SCHED: Ethernet Bridge Process: install watched boolean System Initialized(5D68374), os:1 ah:0APAVC Protocol list already initialized.
*Mar 1 00:00:20.011: Start STILE Activation
APAVC: Succeeded to activate all the STILE protocols.
APAVC: Registering with CFT
*Mar 1 00:00:20.255: APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:00:20.255: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:21.275: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Dec 18 14:29:19.067: %SYS-5-RESTART: System restarted --
*Dec 18 14:29:19.067: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Dec 18 14:29:19.131: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized(5D68374)
*Dec 18 14:29:19.131: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue(AA6ED60), os:0 ah:0
*Dec 18 14:29:19.203: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
--More--
*Dec 18 14:40:44.339: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246
*Dec 18 14:40:44.403: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Dec 18 14:40:44.403: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Dec 18 14:40:55.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:40:55.279: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:40:55.279: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.0.5
*Dec 18 14:41:13.319: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246
*Dec 18 14:41:13.383: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Dec 18 14:41:13.383: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Dec 18 14:41:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:41:23.303: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:41:23.303: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.0.5
*Dec 18 14:41:41.343: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246
*Dec 18 14:41:41.407: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Dec 18 14:41:41.407: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Dec 18 14:41:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:41:51.279: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:41:51.283: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.0.5
*Dec 18 14:42:09.323: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246
*Dec 18 14:42:09.387: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Dec 18 14:42:09.387: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Dec 18 14:42:20.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:42:20.275: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:42:20.279: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.0.5
*Dec 18 14:42:38.319: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246
*Dec 18 14:42:38.383: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Dec 18 14:42:38.383: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Dec 18 14:42:48.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:42:48.279: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:42:48.279: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.0.5
*Dec 18 14:43:06.319: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246
*Dec 18 14:43:06.383: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Dec 18 14:43:06.383: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Dec 18 14:43:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:43:17.279: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.0.5 peer_port: 5246
*Dec 18 14:43:17.279: %CAPWAP-5-SENDJOIN: sending Join Request t*Dec 18 14:29:19.207: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Dec 18 14:29:19.211: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
I have googled this %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.5:5246 and did ap cert expire command on wlc and other command, it didn't help
10 previous AP-s have succesfully joined this WLC, but this one, nope
Thanks in advance
18 Replies 18
check the link I share above
MHM
Yeah, i have just read it, so basically i should upgrade my WLC to newer image.
Because i don't have any other problem with flash except for:
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
@Majlo97 wrote:
APd072.dc2b.0dfc>set_radio_pwr_mode: bad radio unit# 0
Raise a TAC Case and get the AP RMAed.
The 5.0 Ghz radio is dead.
This is a very common thing.  I have RMAed about 20 APs with dead 5.0 Ghz radios in the last 5 years.
Yep in fact that's both radios dead.
