AP power managment
HI All
I have 13 x C9120AXI- aps plugged into a 2960 switch (POE). I am up to maximum watts capacity.
I would like to get one more AP onboarded.
Is there a way of tweaking the APs power on the following WLC  please ?
Cisco Catalyst 9800-L Wireless Controller
Thanks in Advance
17.3.3
Leo Laohoo
Plain 2960 only supports up to 15.4wac.
Catalyst 9k APs require, at a minimum, >25.0wac.
Anything below that and the AP will not power up.
The output from the command "sh power inline" shows the switch has ran out of PoE allowance.
There is nothing else to be done except get another switch or get a switch that is "FP" (higher PoE allowance of 750wac vs the current one of 375wac).
11 Replies 11
balaji.bandi
Can you post the Cat 2960 switch port config where the AP conected ?
also post from switch -
show version
show power inline
some Syntax may help you :
Step 3
power inline {auto [max max-wattage] | never | static [max max-wattage]}
Configure the PoE mode on the port. The keywords have these meanings:
auto—Enable powered-device detection. If enough power is available, automatically allocate power to the PoE port after device detection. This is the default setting.
(Optional) max max-wattage—Limit the power allowed on the port. The range is 4000 to 15400 milliwatts. If no value is specified, the maximum is allowed (15400 milliwatts).
never—Disable device detection, and disable power to the port.
Note
If a port has a Cisco powered device connected to it, do not use the power inline never command to configure the port. A false link-up can occur, placing the port into an error-disabled state.
static—Enable powered-device detection. Pre-allocate (reserve) power for a port before the switch discovers the powered device. The switch reserves power for this port even when no device is connected and guarantees that power will be provided upon device detection.
The switch allocates power to a port configured in static mode before it allocates power to a port configured in auto mode.
BB
interface GigabitEthernet1/0/18
switchport access vlan 6
switchport trunk native vlan 6
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
end
NWGB-H2P-APSW01#sh int g1/0/18
GigabitEthernet1/0/18 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 00ca.e5ba.5812 (bia 00ca.e5ba.5812)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
what is the output :
show power inline
BB
(Watts) (Watts) (Watts)
1 370.0 360.8 9.2
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto off 0.0 n/a n/a 30.0
Gi1/0/2 auto off 0.0 n/a n/a 30.0
Gi1/0/3 auto off 0.0 n/a n/a 30.0
Gi1/0/4 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/5 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/6 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/7 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/8 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/9 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/10 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/11 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/12 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/13 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto on 30.0 C9120AXI-E 4 30.0
Gi1/0/16 auto on 15.4 C9120AXI-E 4 30.0
Gi1/0/17 auto on 15.4 C9120AXI-E 4 30.0
Gi1/0/18 auto power-deny 0.0 n/a n/a 30.0
Gi1/0/19 auto off 0.0 n/a n/a 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
Gi1/0/21 auto off 0.0 n/a n/a 30.0
Gi1/0/22 auto off 0.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
Gi1/0/25 auto off 0.0 n/a n/a 30.0
Gi1/0/26 auto off 0.0 n/a n/a 30.0
Gi1/0/27 auto off 0.0 n/a n/a 30.0
Gi1/0/28 auto off 0.0 n/a n/a 30.0
Gi1/0/29 auto off 0.0 n/a n/a 30.0
Gi1/0/30 auto off 0.0 n/a n/a 30.0
Gi1/0/31 auto off 0.0 n/a n/a 30.0
Gi1/0/32 auto off 0.0 n/a n/a 30.0
Gi1/0/33 auto off 0.0 n/a n/a 30.0
Gi1/0/34 auto off 0.0 n/a n/a 30.0
Gi1/0/35 auto off 0.0 n/a n/a 30.0
Gi1/0/36 auto off 0.0 n/a n/a 30.0
Gi1/0/37 auto off 0.0 n/a n/a 30.0
Gi1/0/38 auto off 0.0 n/a n/a 30.0
Gi1/0/39 auto off 0.0 n/a n/a 30.0
Gi1/0/40 auto off 0.0 n/a n/a 30.0
Gi1/0/41 auto off 0.0 n/a n/a 30.0
Gi1/0/42 auto off 0.0 n/a n/a 30.0
Gi1/0/43 auto off 0.0 n/a n/a 30.0
Gi1/0/44 auto off 0.0 n/a n/a 30.0
Gi1/0/45 auto off 0.0 n/a n/a 30.0
Gi1/0/46 auto off 0.0 n/a n/a 30.0
Gi1/0/47 auto off 0.0 n/a n/a 30.0
Gi1/0/48 auto off 0.0 n/a n/a 30.0
as per the output, as you mentioned you are out of power.
but one of the surprising was, same model AP different PoE consumption :
Do you see different config on the switch ports gi 1/0/16 and 17 compare to gi 1/0/15?
as other post given informaiton based on the AP power consumption listed in Datasheet for reference :
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9120ax-series-access-points/datasheet-c78-742115.html
BB
No difference in port config
I don't think you want to try to tweak anything that can cause you issues latter on.  Why not just buy a power injector or better yet, get another switch that you can use in the future for ap's or other PoE devices.
-Scott
not sure what model of switch, uplift the PSU to get more device added, rather overload.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/hardware/installation/guide/b_c2960xr_hig/m_pwr_sup_install_hig.html
BB
these are the power consumptions guide for this AP. you have to adhere with that and do tweaks.
PoE power consumption
2.4-GHz radio
5-GHz radio
Link speed
USB
LLDP
802.3at (PoE+)
4x4
4x4
2.5G
Y
25.5W
Catalyst 9120AXI, 9120AXE, 9120AXP
2.4-GHz radio
5-GHz radio
Link speed
USB
LLDP
802.3af
PoE
1x1
1x1
1G
N
13.4W
802.3af
PoE
2x2
N
1G
N
13.4W
802.3af
PoE
N
2x2
1G
N
13.4W
Good luck
KB
These are the flexible power options for Cat 9120 APs.
AP Model
Power source
Power Type
2.4 GHz Radio
5 GHz Radio
Link Speed
USB
Power Draw
C9120AXI / C9120AXE
802.3at
PoE+
4x4
4x4
2.5G
ON
25.5W
C9120AXI / C9120AXE
802.3af
PoE
1x1
1x1
1G
OFF
13.4 W
C9120AXI / C9120AXE
802.3af
PoE
2x2
N
1G
OFF
13.4 W
C9120AXI / C9120AXE
802.3af
PoE
N
2x2
1G
OFF
13.4 W
If possible move APs to different switch, so that you don't degrade AP performance.
If you add an extra AP, it may not get required power. You may try rebooting couple of existing APs with 30w power consumption once you add the new AP and they may come up with PoE power and the new AP gets enough power to run. Not tested, but you can try.
CJ
Leo Laohoo
