- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-23-2024 06:58 AM
From the WLC we see
Reason for last AP connection failure Max Retransmission AP
(This is on all the AP's at this site)
Also from debug logs we see many many instances of this
2024/10/21 07:33:53.162822 {wncd_x_R0-2}{1}: [apmgr-capwap-config] [22172]: (ERR): 2481.3b23.7c20 The reboot reason received from AP is out of range - 67
2024/10/21 07:33:53.163623 {wncd_x_R0-2}{1}: [apmgr-db] [22172]: (ERR): TRAP rebootreason_set failed
2024/10/21 07:33:53.163625 {wncd_x_R0-2}{1}: [apmgr-db] [22172]: (ERR): TRAP dataencryptionstatus_set failed
2024/10/21 07:33:54.207035 {wncd_x_R0-2}{1}: [capwapac-smgr-srvr] [22172]: (note): MAC: 2481.3b23.7c20 Successfully handled Config status request.
2024/10/21 07:33:54.207444 {wncd_x_R0-2}{1}: [apmgr-db] [22172]: (ERR): TRAP rebootreason_set failed
2024/10/21 07:33:54.207446 {wncd_x_R0-2}{1}: [apmgr-db] [22172]: (ERR): TRAP dataencryptionstatus_set failed
2024/10/21 07:33:54.400861 {wncd_x_R0-2}{1}: [capwapac-smgr-srvr] [22172]: (note): MAC: 2481.3b23.7c20 Successfully handled Config status request.
2024/10/21 07:33:54.401293 {wncd_x_R0-2}{1}: [apmgr-db] [22172]: (ERR): TRAP rebootreason_set failed
2024/10/21 07:33:54.401295 {wncd_x_R0-2}{1}: [apmgr-db] [22172]: (ERR): TRAP dataencryptionstatus_set failed
Ideas please before this goes to TAC. Thanks in advance
Solved! Go to Solution.
- Labels:
Catalyst Wireless Controllers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2024 07:36 AM
Can you share complete boot log for the AP.
Cisco has announced the End of Life (EoL) for IOS XE Bengaluru 17.6. There is only one more Maintenance Release (MR) planned for the 17.6 train, which will address security fixes only. If you need to stay on the 17.6.x code, you should upgrade to version 17.6.7.
EoL notification: Cisco EoL for IOS XE 17.6.x
Cisco recommends upgrading to 17.9.5 for all deployments. At present, both 17.9.5 and 17.12.3 are recommended versions.
Reference: Cisco TAC Recommended IOS XE Builds
I suggest upgrading your code to avoid potential bugs.
Jagan Chowdam
/**Pls rate useful responses**/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2024 07:36 AM
Jagan Chowdam
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2024 07:42 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2024 07:39 AM
- Start with a checkup of the 9800 WLC configuration with the CLI command show tech wireless
, not simple show tech , and feed the output from that into Wireless Config Analyzer
- Make sure AP model and country code configured in the controller are aligned
- Make sure AP are in CAPWAP mode (not mesh or something else , if not intended)
- Controller software version is very old , consider moving to 17.12.3, take care of
AP compatibility according to https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
M.
