AP won't join (LAP1242 and WLC 5500 series)
Totardo Tobing
Hi I have a problem
The access point is reply when I ping it from WLC. But until know it can't join, even discovery packet isn't arrive in WLC. How this could be? Please help. Need advice.
WLC software version = 6.0.199.4
Management interface address = 192.168.120.10 /24
Model = 5508
Access point software = 1240 Software (C1240-RCVK9W8-M), Version 12.4(21a)JA2, RELEASE SOFTWARE (fc1)
AP Model = cisco AIR-LAP1242G-E-K9
Interface address = 192.168.121.151
3 Accepted Solutions
Like Leo mentioned, console into the AP and attach the output of the whole boot up and join process. Like 5 minutes... This will help us understand why the ap is not joining.
-Scott
Quick question, are there other AP's on this controller already??  If not double check the date and time on the controller to make sure they are right. if no ap's are on this controller also check the AP Policy under security and make sure it will accept Manufacturer Installed Certificates.
you can try to telnet to the AP using it's DHCP address and the default UN: cisco  & PW: Cisco
Make sure you haven't disabled the option to accept MIC certificates from the AP. See security page on the controller and AP policies. Make sure that MIC is ticked.
19 Replies 19
Scott Fella
Well the AP and the wlc is in a different subnet, so you will need to do option 43, DNS, or place the AP in the same subnet as the wlc. Once the AP has joined, it can be placed back in the other subnet.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
-Scott
DHCP option 43 confirmed--> I already create DHPC option 43 but still won't join.
Still the access point is success when I give a ping to it from the WLC.
I can't ask the DNS on my client, it's too complicated to ask and I don't now how to configure DNS
Leo Laohoo
Console into the WAP and reboot the WAP.
Post the entire bootup process including the joining process.
Marco Gonzalez
If you want to add this only access point to the wireless LAN controller one very eay way to do this is by configuring an static IP to the access point and configuring the IP address of the wireless LAN controller directly on the access point via console by entering the following commands:
    AP1240# lwapp ap ip address 192.168.121.151 255.255.255.0
    AP1240# lwapp ap ip default-gateway 192.168.121.1  << I guess>>
    AP1240# lwapp ap controller ip address 192.168.120.10
Yes, it is indeed what is I do with the LAP. I configure it static: their ip address, their controller address. But still won't join.
-Scott
Thanks Scott.
Anytime:)
-Scott
the LAP already mounted 8 metres above us, its hard to climb, we don't have ladder.
Can you share me how to remote log this AP. PS: the AP not yet join. I'm curious too.. Very2x
Thank you Scott
No real way of remote logging. This is what I would do:
Put the access point on the same vlan the wlc management interface is on
Make sure there is dhcp configured on that vlan
On the switch that the ap is connected to, hopefully it's a Cisco switch, issue a show cdp neighbor
Post what that shows
Attach the following in a txt format
show run-config on the wlc
Post the switch port config the ap and the wlc is connected to
-Scott
While you figure out how to get the "sh version" and "sh inventory" of the WAP, if you have Cisco switch, can you please post the complete output to the command "sh cdp n det" and "sh power inline"?
Kayle Miller
Level 7
Level 7
This may seem stupid but could also be overlooked.. I noticed the AP is an -E Regulatory domain, make sure the controller has the -E regulatory domain configured on it, otherwise it can prevent the ap from joining.
Totardo Tobing
@Kayle Miller : No it's good. Not stupid. I already check. WLC and the AP is in same E regulatory domain.
The problem is, WLC never ever receive discovery message from that AP. Can you tell me what would possibility reason of this?
