Bookmark
Subscribe
391
AP1100 in WGB mode
tgrundbacher
I have tried to get the AP1100 running as a workgroup bridge, but no success by now. I am getting the following output:
*Mar 1 00:26:53.917: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No ma
tching privacy setting (from 000e.d7b1.3400)
The config guide to IOS 12.3(4) doesn't say anything about encryption mode <type>, but I tried to match the setting on the upstream AP, and I got the following output:
*Mar 1 00:25:23.003: %DOT11-2-UPLINK_FAILED: Uplink to parent failed: Unsupported authen
tication type
Any ideas?
The config guide doesn't say anything about how to verify or debug the WGB mode, which makes it a little difficult to track the problem.
s-doyle
Level 3
Level 3
A couple of things to do:
1. On the root remove the check mark from the box for Install-Mode.
2. And also remove the wep key on both sides.
3. And on the WGB side remove the 'infrastructure client' for under the radio
interface. Once this is done your setup should work fine.
