10-19-2018 03:27 AM - edited 07-05-2021 09:19 AM
HI, I am using AIR-AP1852-C-K9 Access Point with Mobility Express Software image as controller. The built-in AP is working fine and no other AP is added to the network. I have added two counties US and PK in countries-list. Still AP is NOT broadcasting SSID 802.11b (5GHz). The output of show Sysinfo, 802.11a and 802.11b is attached. Earliest possible from anyone will be highly appreciated.
Solved! Go to Solution.
10-19-2018 08:11 AM
10-19-2018 04:19 AM - edited 10-19-2018 04:20 AM
Hi Jamal,
I think you have a wrong regulatory domain AP /WLC.
for paksitan it must be: AIR-AP1852-G-K9
More info here: https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Talk with your supplier .
Dont forget to rate helpful posts
10-19-2018 05:06 AM
Dear Sandeep,
Thanks for your time and reviewing my issue. I understand that "C" is not for Pakistan. I have tried using "UA" and "AE" but same status. Could you please confirm what country-code should I use to resolve this issue?
10-19-2018 08:11 AM
10-20-2018 03:37 AM
Finally I managed it by using BH, US in country code list.
