AP3802 not broadcast SSID with Mobility Express
cristhiangh
I have a Cisco Aironet 3802 with the image of Mobility Express 8.5.101, I created 3 SSIDs that are not spreading, I already enabled Broadcast SSID in the 3 networks but none is shown, nor like hidden, What could be the problem?
3 Accepted Solutions
Ok that sounds like a POE problem.
3802 will only power the radios with POE+ (30W) and it needs CDP or LLDP to negotiate that.
Does the switch support 30W 802.3at (POE+) on the port (and enough power available) and do you have CDP enabled?
If not it will fallback to 802.3af with 15.4W - enough to run the AP without any radios so that you can troubleshoot and configure it only.
In that case you'll see in the boot logs and on the GUI that the AP is running in low power mode.
"show power inline" and "show cdp neigh detail" on the switch.
Rather than concentrating on logs which might prove to be unimportant fix those things which we know are essential first.
And ME only works in flex mode so that is by design.
Without CDP (or LLDP) it will NOT work - end of story.
So make sure you have that working and see if it solves the problem.  Your testing so far suggests that it will solve the problem.
If not then move onto other possible problems.
Yes, the problem was PoE, my switch only support 802.3af (PoE) 15.4w, I connected to power injector that support 30W and the SSID started to broadcast.
Thank you so much for the support
11 Replies 11
Scott Fella
Are these access points 3802i or 3802e?  If it is the later, then you need to have external antennas.  You should also be able to see the radio states from the gui to see if the radios are up or down.
-Scott
Hi Scott, thank you for your answer, I have a 3802i, the SKU AIR-AP3802I-A-K9, Where can I see the status of the radios if they are up or down?
I have a similar problem. After migrating from CAPWAP to MEX. My AP AIR-AP2802I is not broadcasting the Wi-Fi network. Shows the network for 3 minutes at boot. My log as shown had some errors. I wonder why the radio is switching from local to Flexconnect.
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.40
High speed PHY - Version: 2.0
BoardId = 0x21board SerDes lanes topology details:
 | Lane # | Speed|    Type     |
 |   1    |  0   |  SGMII1     |
 |   2    |  5   |  PCIe1      |
 |   4    |  5   |  PCIe2      |
 |   5    |  0   |  SGMII2     |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
  ____  _
 / ___|(_) ___   ___  ___
| |    | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
 \____||_||___/ \___|\___/
         _   _     ____              _
        | | | |   | __ )  ___   ___ | |_
        | | | |___|  _ \ / _ \ / _ \| __|
        | |_| |___| |_) | (_) | (_) | |_
         \___/    |____/ \___/ \___/ \__|
 ** LOADER **
U-Boot 2013.01-gcb01933d4 (Nov 10 2020 - 23:41:12) SDK version: 2015_T2.0p10
Board: Barbados-2K
SoC:   MV88F6920 Rev A1
       running 2 CPUs
CPU:   ARM Cortex A9 MPCore (Rev 1) LE
       CPU 0
       CPU    @ 1800 [MHz]
       L2     @ 900 [MHz]
       TClock @ 250 [MHz]
       DDR4    @ 900 [MHz]
       DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM:  1 GiB
RST I2C0
NAND:  ECC 4bits, 256 MiB
SF: Detected MX25L3205D with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map:   Code:                    0x3fed8000:0x3ffae360
       BSS:                     0x3ffefe24
       Stack:                   0x3f9c7f20
       Heap:                    0x3f9c8000:0x3fed8000
       U-Boot Environment:      0x00100000:0x00110000 (SPI)
Board configuration:
|  port  | Interface  | PHY address  |
| egiga1 |   SGMII    |     0x01     |
| egiga2 |   SGMII    |     0x00     |
Net:   , egiga1, egiga2 [PRIME]
Hit ESC key to stop autoboot:  0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 0, name "part1"
Loading file 'part1/part.bin' to addr 0x02000000 with size 6273845 (0x005fbb35).        ..
Done
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
   Image Name:   Barbados Firmware Image
   Created:      2021-03-04  11:15:15 UTC
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    6272837 Bytes = 6 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Contents:
      Image 0: 4202632 Bytes = 4 MiB
      Image 1: 2054051 Bytes = 2 MiB
      Image 2: 16137 Bytes = 15.8 KiB
   Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
   Booting using the fdt at 0x025f787c
   Loading Multi-File Image ... OK
OK
   reserving fdt memory region: addr=0 size=4000
   Loading Device Tree to 01ff9000, end 01ffff08 ... OK
   Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 1025868K/1048576K available (5743K kernel code, 411K rwdata, 2476K rodata, 359K init, 496K bss, 22708K reserved, 0K hig                                   hmem)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:01.4300] buginf tty flushing thread started, ttyport=be928c00
[01/01/1970 00:00:01.5500] m25p80 spi1.0: found mx25l3206, expected n25q032
[*01/01/1970 00:00:02.7040] buginf() enabled.
[*01/01/1970 00:00:02.7137] Made it into bootsh: Mar  4 2021 10:13:22 T-0b7bc0faa97ae8a26ea605c7622aac357397184c-g0b7bc0fa-aut
[*01/01/1970 00:00:13.4761] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
            Cisco Systems, Inc.
            170 West Tasman Drive
            San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[*01/01/1970 00:00:39.4343] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:39.4374] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:39.4901] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:39.4931] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[  OK  ] Reached target Timers.
[  OK  ] Created slice -.slice.
[  OK  ] Created slice system.slice.
         Starting Cisco UBIFS reformat/mount...
[  OK  ] Listening on Delayed Shutdown Socket.
[  OK  ] Reached target Slices.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Reached target Cisco File Systems (Pre).
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on udev Kernel Socket.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Sockets.
         Starting udev Coldplug all Devices...
[  OK  [01/01/1970 00:00:44.9400] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
[01/01/1970 00:00:44.9400] audit: printk limit exceeded
] Started udev Kernel Device Manager.
[  OK  ] Started Cisco UBIFS reformat/mount.
         Starting Cisco early mount...
[  OK  ] Started Cisco early mount.
[  OK  ] Reached target Local File Systems (Pre).
         Starting Cisco platform file generation...
         Starting Cisco seed generation...
         Starting Cisco system time setup...
         Starting Cisco fips check...
[  OK  ] Started Cisco seed generation.
[*11/18/2018 23:59:59.0751] Last reload time: Apr 5 09:37:47 2021
[*04/05/2021 09:37:47.0082] Setting system time Mon Apr  5 09:37:47 UTC 2021
[  OK  ] Started Cisco system time setup.
[  OK  ] Started Cisco fips check.
[  OK  ] Started Cisco platform file generation.
         Starting Cisco btldr service...
[  OK  ] Started Cisco btldr service.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target Local File Systems.
         Starting Cisco S10 boot service...
         Starting Cisco pkg install service...
[*04/05/2021 09:37:48.4025] GCM-128 POST passed
[*04/05/2021 09:37:48.4025] GCM-256 POST passed
[*04/05/2021 09:37:49.8762] /etc/init.d/S10boot: Warning: deleting backup ap images to save storage...
[*04/05/2021 09:37:49.8913] 1
         Starting Cisco act2 check...
[*04/05/2021 09:37:50.1007] Active version: 8.10.151.0
[*04/05/2021 09:37:50.1046] Backu[  OK  ] Started Cisco system time saving.
         Starting Cisco system time saving...
         Starting Security Auditing Service...
[*04/05/2021 09:37:50.3522] parameter passed without an option given
[*04/05/2021 09:37:50.4374] device wired0 entered promiscuous mode
[  OK  ] Started Security Auditing Service.
[04/05/2021 09:37:50.6700] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
[04/05/2021 09:37:50.7600] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
[  OK  ] Started Cisco pkg install service.
[04/05/2021 09:37:57.1800] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
[04/05/2021 09:37:57.2600] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
[  OK  ] Started Cisco act2 check.
[  OK  ] Started Cisco S10 boot service.
         Starting Cisco watchdog...
         Starting Cisco nss service...
[*04/05/2021 09:37:50.8430] wifi0: Initializing TX ring
[*04/05/2021 09:37:50.8475] wifi0: Initializing RX ring
[*04/05/2021 09:37:50.8524] wifi0: prepare firmware downloading
[*04/05/2021 09:37:51.6959] wifi0: Firmware downloading
[*04/05/2021 09:37:52.9442] 0;
[*04/05/2021 09:37:53.2302]
[*04/05/2021 09:37:53.2302] Authenticating ACT2 ID:AP2800
[*04/05/2021 09:37:53.2302] Authenticating SN:XXXXXXXXXXXX
[*04/05/2021 09:37:53.2308]
[*04/05/2021 09:37:53.2308] (ACT2Boot) Hardware is Cisco (c) authentic :-)
[*04/05/2021 09:37:53.2382] Seeding /dev/urandom from ACT2
[*04/05/2021 09:37:53.5749] 0;0;<30>systemd[1]: Started Cisco pkg install service.
[*04/05/2021 09:37:54.7409] 0;Reading ACT2 SUDI certificates
[*04/05/2021 09:37:55.2509] 0;0;0;
[*04/05/2021 09:37:56.6869] Firmware download complete
[*04/05/2021 09:37:56.8829] wifi0: Getting HW specs. Retrying for 3
[*04/05/2021 09:37:56.8832] Mac_Init
[*04/05/2021 09:37:56.8836] Preparing to set HW specs
[*04/05/2021 09:37:56.8839] FIPS enc aes-ccmp Verified
[*04/05/2021 09:37:56.8840] FIPS dec aes-ccmp Verified
[*04/05/2021 09:37:56.8841] FIPS enc aes-ccmp-256 Verified
[*04/05/2021 09:37:56.8842] FIPS dec aes-ccmp-256 Verified
[*04/05/2021 09:37:56.8843] FIPS enc aes-gcmp Verified
[*04/05/2021 09:37:56.8844] FIPS dec aes-gcmp Verified
[*04/05/2021 09:37:56.8845] FIPS enc aes-gcmp-256 Verified
[*04/05/2021 09:37:56.8846] FIPS dec aes-gcmp-256 Verified
[*04/05/2021 09:37:57.3457] wifi1: Initializing TX ring
[*04/05/2021 09:37:57.3493] wifi1: Initializing RX ring
[*04/05/2021 09:37:57.3540] wifi1: prepare firmware downloading
[*04/05/2021 09:37:58.1785] wifi1: Firmware downloading
[*04/05/2021 09:37:59.3969] 0;0;0;0;0;0;0;
[*04/05/2021 09:38:02.6149] Firmware download complete
[*04/05/2021 09:38:02.8129] wifi1: Getting HW specs. Retrying for 3
[*04/05/2021 09:38:02.8132] Mac_Init
[*04/05/2021 09:38:02.8136] Preparing to set HW specs
[*04/05/2021 09:38:02.8138] FIPS enc aes-ccmp Verified
[*04/05/2021 09:38:02.8139] FIPS dec aes-ccmp Verified
[*04/05/2021 09:38:02.8140] FIPS enc aes-ccmp-256 Verified
[*04/05/2021 09:38:02.8142] FIPS dec aes-ccmp-256 Verified
[*04/05/2021 09:38:02.8143] FIPS enc aes-gcmp Verified
[*04/05/2021 09:38:02.8144] FIPS dec aes-gcmp Verified
[*04/05/2021 09:38:02.8145] FIPS enc aes-gcmp-256 Verified
[*04/05/2021 09:38:02.8146] FIPS dec aes-gcmp-256 Verified
[*04/05/2021 09:38:03.8883] Last reload reason : 0: unknown
[*04/05/2021 09:38:04.0581] Initializing NSS Firmware
         Starting Cisco nolan service...
[  OK  ] Started Cisco watchdog.
[  OK  ] Started Cisco nolan service.
         Starting Cisco nolan USB service...
[  OK  ] Started Cisco nolan USB service.
[  OK  ] Started Cisco pre-PoE negotiation.
         Starting Cisco pre-PoE negotiation...
[  OK  ] Started Cisco nss service.
         Starting Cisco S15platform...
         Starting Cisco Kclick...
[04/05/2021 09:38:07.6900] Disabling lock debugging due to kernel taint
[  OK  ] Started Cisco S15platform.
[  OK  ] Started Cisco Kclick.
         Starting Cisco ME service...
         Starting Cisco Sku service...
[*04/05/2021 09:38:07.9023] stile module dp init successfully
[*04/05/2021 09:38:07.9023] NBAR Label:BLD_POLARIS_DEV_LATEST_20200414_053707 Module timestamp: Mar  4 2021 at 10:02:28 User: ttaichol
[*04/05/2021 09:38:10.6335] SKU to radio FW
[*04/05/2021 09:38:10.7121] wifi2     no private ioctls.
         Starting Cisco certificate create service...
[  OK  ] Started Cisco Sku service.
[  OK  ] Started Cisco ME service.
[04/05/2021 09:38:11.2800] xt_CONNSECMARK: Unknown symbol nf_ct_l3proto_module_put (err 0)
[04/05/2021 09:38:11.3800] xt_CONNSECMARK: Unknown symbol xt_register_target (err 0)
[04/05/2021 09:38:11.4700] xt_CONNSECMARK: Unknown symbol nf_ct_l3proto_try_module_get (err 0)
[04/05/2021 09:38:11.5700] xt_CONNSECMARK: Unknown symbol xt_unregister_target (err 0)
[  OK  ] Started Cisco [04/05/2021 09:38:11.6900] xt_SECMARK: Unknown symbol xt_register_target (err 0)
certificate crea[04/05/2021 09:38:11.7800] xt_SECMARK: Unknown symbol xt_unregister_target (err 0)
te service.
         Starting rsyslog client...
         Starting Cisco syslog service...
         Starting Cisco S16platfomm...
[*04/05/2021 09:38:11.6160]  Create symlink /dev/mic_cert result 0
[*04/05/2021 09:38:11.6160] Loading certificates from storage...
[*04/05/2021 09:38:11.6398] barbados /tmp/SC4_1dbm.txt
[  OK  ] Started Cisco Tam service.
         Starting Cisco Tam service...
         Starting Cisco certtime service...
[  OK  ] Started rsyslog client.
[  OK  ] Started Cisco syslog service.
[  OK  ] Started Cisco S16platfomm.
         Starting Cisco synclogd...
[  OK  ] Started Cisco synclogd.
[  OK  ] Started Cisco certtime service.
[*04/05/2021 09:38:17.4952] starting tam services using ACT2...
[*04/05/2021 09:38:17.4952] TAM init done
[*04/05/2021 09:38:17.6729]
[*04/05/2021 09:38:17.6729] Click sched monitor: schedulers = 1
[  OK  ] Reached target System Initialization.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Basic System.
[  OK  ] Started Serial Getty on ttyS0.
         Starting Serial Getty on ttyS0...
[  OK  ] Reached target Login Prompts.
         Starting Cisco brain service...
         Starting Hostapd process...
         Starting Cisco kexec...
         Starting Cisco printkd...
         Starting Cisco klogd...
         Starting WCPD process...
[  OK  ] Started System Monitor service.
         Starting System Monitor service...
         Starting Cisco image/firmware updater service...
         Starting capwapd...
         Starting Marvell Forwarding daemon...
         Starting Fast CGI daemon...
         Starting gRPC server daemon...
         Starting Cisco rtd service...
         Starting OpenSSH server daemon...
         Starting Cisco led service...
         Starting Clean Air daemon...
[  OK  ] Started NTP_PROC daemon.
         Starting NTP_PROC daemon...
         Starting AP Trace daemon...
[  OK  ] Started Cisco kexec.
[  OK  ] Started Cisco image/firmware updater service.
[  OK  ] Started Cisco klogd.
[  OK  ] Started Cisco printkd.
[  OK  ] Started Fast CGI daemon.
[  OK  ] Started Cisco rtd service.
[  OK  ] Started AP Trace daemon.
[  OK  ] Started Hostapd process.
[  OK  ] Started Cisco led service.
[  OK  ] Started Cisco brain service.
[04/05/2021 09:38:20.5500] wired0 emac 2: link up
[04/05/2021 09:38:20.6100] wired0: link up
[  OK  ] Started OpenSSH server daemon.
No valid user found, please configure a valid user from Controller[04/05/2021 09:38:30.4700] wired0 emac 2: link up
[04/05/2021 09:38:30.5200] wired0: link up
[*04/05/2021 09:38:30.8326]
[*04/05/2021 09:38:30.8326] !!!!! {/opt/cisco/bin/capwap_brain} failed writing /click/vrrp_elector/preferred_ap_name len 0 data: ""
[*04/05/2021 09:38:31.1449] pid 7344's current affinity mask: 3
[*04/05/2021 09:38:31.1449] pid 7344's new affinity mask: 1
[*04/05/2021 09:38:31.2491] ip6_port srcr2, ip6local fe80::72b3:17ff:fea2:8faa, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*04/05/2021 09:38:31.9731] device aptrace0 entered promiscuous mode
[*04/05/2021 09:38:32.0031] device to_container entered promiscuous mode
[*04/05/2021 09:38:32.6817] chpasswd: password for user changed
[*04/05/2021 09:38:33.3586] USB Device Disconnected from the AP
[*04/05/2021 09:38:33.6371] DOT11_TXP[0]:Domain configured: 12 class:E
[*04/05/2021 09:38:34.0843] DOT11_TXP[0]:Domain configured: 12 class:E
[*04/05/2021 09:38:34.5359] DOT11_TXP[0]:Domain configured: 1 class:E
[*04/05/2021 09:38:34.6296] DOT11_TXP[0]:Domain configured: 1 class:E
[*04/05/2021 09:38:34.7148] DOT11_TXP[1]:Domain configured: 12 class:E
[*04/05/2021 09:38:35.9334] DOT11_DRV[0]: Stopped Radio 0
[*04/05/2021 09:38:35.9638] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 6
[*04/05/2021 09:38:36.9677] DOT11_DRV[1]: Stopped Radio 1
[*04/05/2021 09:38:36.9955] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:37.5478] DOT11_CFG[0] Radio Mode is changed from Local to FlexConnect
[*04/05/2021 09:38:37.5583] DOT11_CFG[0]: Starting radio 0
[*04/05/2021 09:38:37.5862] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 6
[*04/05/2021 09:38:38.2196] chatter: wl0: Beacon rate info: Previous: 0 Current: 252183808
[*04/05/2021 09:38:38.2196] chatter: wl0: Beacon PID : Previous: 0 Current: 8
[*04/05/2021 09:38:38.2349] DOT11_DRV[0]: Started Radio 0
[*04/05/2021 09:38:38.2355] DOT11_CFG[1] Radio Mode is changed from Local to FlexConnect
[*04/05/2021 09:38:38.2361] DOT11_CFG[1]: Starting radio 1
[*04/05/2021 09:38:38.2634] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:38.8880] chatter: wl1: Beacon rate info: Previous: 0 Current: 252183808
[*04/05/2021 09:38:38.8880] chatter: wl1: Beacon PID : Previous: 0 Current: 8
[*04/05/2021 09:38:38.9026] DOT11_DRV[1]: Started Radio 1
[*04/05/2021 09:38:39.8589] DOT11_DRV[0]: Stopped Radio 0
[*04/05/2021 09:38:39.8827] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:39.9098] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:40.5532] DOT11_DRV[0]: Started Radio 0
[*04/05/2021 09:38:41.3956]
[*04/05/2021 09:38:41.3956] !!!!! {/opt/cisco/bin/capwap_brain} failed writing /click/vrrp_elector/preferred_ap_name len 0 data: ""
[*04/05/2021 09:38:41.4530] ethernet_port wired0, ip 192.168.11.217, netmask 255.255.255.0, gw 192.168.11.1, mtu 1500, bcast 192.168.11.255, dns1 192.168.11.1, domain home, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*04/05/2021 09:38:41.5844] DOT11_DRV[0]: Stopped Radio 0
[*04/05/2021 09:38:41.6099] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:41.6384] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:42.2801] DOT11_DRV[0]: Started Radio 0
[*04/05/2021 09:38:42.2951] DOT11_DRV[0]: Stopped Radio 0
[*04/05/2021 09:38:42.3189] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:42.3462] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:42.9818] DOT11_DRV[0]: Started Radio 0
[*04/05/2021 09:38:44.3619] bftype is 6
[*04/05/2021 09:38:44.4671] DOT11_DRV[0]: Stopped Radio 0
[*04/05/2021 09:38:44.4925] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:44.6390] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:45.3931] DOT11_DRV[0]: Started Radio 0
[*04/05/2021 09:38:46.4146] DOT11_DRV[0]: Stopped Radio 0
[*04/05/2021 09:38:46.4400] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:46.5888] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*04/05/2021 09:38:47.3431] DOT11_DRV[0]: Started Radio 0
[*04/05/2021 09:38:48.7417] DOT11_DRV[1]: Stopped Radio 1
[*04/05/2021 09:38:48.7663] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:48.7942] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:49.4425] DOT11_DRV[1]: Started Radio 1
[*04/05/2021 09:38:50.4974] DOT11_DRV[1]: Stopped Radio 1
[*04/05/2021 09:38:50.5227] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:50.5505] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:51.2005] DOT11_DRV[1]: Started Radio 1
[*04/05/2021 09:38:52.2280] DOT11_DRV[1]: Stopped Radio 1
[*04/05/2021 09:38:52.2527] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:52.2805] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:52.9305] DOT11_DRV[1]: Started Radio 1
[*04/05/2021 09:38:52.9629] DOT11_DRV[1]: Stopped Radio 1
[*04/05/2021 09:38:52.9882] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:53.0171] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:53.6670] DOT11_DRV[1]: Started Radio 1
[*04/05/2021 09:38:55.2399] DOT11_DRV[1]: Stopped Radio 1
[*04/05/2021 09:38:55.2573] bftype is 6
[*04/05/2021 09:38:55.3023] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:56.2502] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:57.1884] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*04/05/2021 09:38:57.5328] Socket Valid Element wcp/wcp_db Handler set_vlan_name_map Data  Length 10
[*04/05/2021 09:38:57.5361] Failed to send msg to wcp/Radio2.set_radius_extended_config
[*04/05/2021 09:38:58.9568] AP IPv4 Address updated from 0.0.0.0 to 192.168.11.217
[*04/05/2021 09:39:12.0681]
[*04/05/2021 09:39:12.0681] !!!!! {/opt/cisco/bin/capwap_brain} failed writing /click/host_firewall_ssh/switch len 1 data: "0"
[*04/05/2021 09:39:12.1674] chatter: tohost_virtual :: ToHost: device 'virtual' went down
[*04/05/2021 09:39:12.2372] chatter: tohost_vlan0 :: ToHost: device 'vlan0' went down
[*04/05/2021 09:39:12.2671] chatter: tohost_vlan1 :: ToHost: device 'vlan1' went down
[*04/05/2021 09:39:12.3069] chatter: tohost_vlan2 :: ToHost: device 'vlan2' went down
[*04/05/2021 09:39:12.3369] chatter: tohost_vlan3 :: ToHost: device 'vlan3' went down
[*04/05/2021 09:39:12.3771] chatter: tohost_vlan4 :: ToHost: device 'vlan4' went down
[*04/05/2021 09:39:12.4170] chatter: tohost_vlan5 :: ToHost: device 'vlan5' went down
[*04/05/2021 09:39:12.4669] chatter: tohost_vlan6 :: ToHost: device 'vlan6' went down
[*04/05/2021 09:39:12.5171] chatter: tohost_vlan7 :: ToHost: device 'vlan7' went down
[*04/05/2021 09:39:12.5669] chatter: tohost_vlan8 :: ToHost: device 'vlan8' went down
[*04/05/2021 09:39:12.6070] chatter: tohost_vlan9 :: ToHost: device 'vlan9' went down
[*04/05/2021 09:39:12.6472] chattStarting the Switchdriver...
Starting Switchdriver...
Cryptographic library self-test....
Testing SHA1 Short Message 1
Testing SHA256 Short Message 1
Testing SHA384 Short Message 1
SHA1 POST PASSED
Testing HMAC SHA1 Short Message 1
Testing HMAC SHA2 Short Message 1
Testing HMAC SHA384 Short Message 1
passed!
XML config selected
Starting SSHD: ok
Starting Redis-Server: ok
Starting naconnector: ok
Starting nginx: ok
Validating XML configuration
Starting NA Connector...
creating logs dir
Starting DB Services...
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 8.10.151.0
Initializing OS Services: ok
Initializing Serial Services: ok
Initializing Network Services: ok
Starting PNP: ok
Starting Statistics Service: ok
Unable to open dx flag file
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Data Externalization services: ok
Starting Network Interface Management Services: ok
Starting System Services: ok
Starting SNMP services: ok
Starting Fastpath Hardware Acceleration: Starting Switching Services: ok
Starting QoS Services: ok
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces: ok
Starting Client Troubleshooting Service: ok
Starting Certificate Database: Initializing Curl Globally..
ok
Starting VPN Services: ok
Starting Management Frame Protection: ok
Starting DNS Services: ok
Starting Secure Tunnelling Services: ok
ok
Starting LWAPP: ok
Starting CAPWAP: ok
Starting LOCP: ok
Starting Security Services: ok
Starting OpenDNS Services: ok
Starting Authentication Engine: ok
Starting Capwap Ping Component: ok
Starting AVC Services: ok
Starting AVC Flex Services: ok
Starting Virtual AP Services: ok
Starting AireWave Director: ok
Starting Network Time Services: open rrm: not able to ipv4 by pass rule ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
Starting RF Profiles: ok
Starting Mesh Services:  ok
Starting TSM: ok
Starting CIDS Services: ok
Starting DTLS server:  enabled in CAPWAP
In hreapLoadConfig. Loading config has failed. loading default config
Starting CleanAir: ok
Starting WIPS: ok
Starting SSHPM LSC PROV LIST: ok
Starting RRC Services: ok
Starting Alarm Services: ok
Starting FMC HS: ok
Starting FLEXEXPRESS ConfigSync Task: ok
Starting HTTP Image Download Task: ok
Starting Tunnel Services New: ok
Starting mDNS Services: ok
Starting Management Services:
   Web Server: Starting IPSec Profiles component:    CLI:    Secure Web: ok
ok
Enabling Controller Provisioning
 Hostname is not compliant to RFC !.
Hostname can contain max of 31 characters namely Upper/lowercase letters,digits,dot,hyphen.
Hostname should always start with an alphabet or digit and should not end with '.' or '-'.
PnP config is saved to storage
 Configuring management interfacesh: write error: Broken pipe
 Enabling mgmt via wireless
 Enabling Provisioning SSID
 SSID: CiscoAirProvision, Admin Status: 1, Interface Name: management, 802.11 Auth: WPA2-PSK,  Wi-Fi Protected Access : Enabled
(Cisco Controller)
Cisco Aironet 2800 Series Mobility Express
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
Enter Administrative User Name (24 characters max):
- ME only supports Flex
- "Welcome to the Cisco Wizard Configuration Tool" - your ME WLC has not been configured - you need to run through initial configuration.  Follow the instructions starting with entering the admin user name.
cristhiangh
Hi everyone,
I disconnected the AP from the Switch where I had it connected, a Catalyst 3750, and connected it directly to a cable modem, energizing it with Power injector and it worked, it broadcast the SSIDs, I think the problem is the configuration that I have in the switch
Will you have an example of how to configure the swtich?
What about my case. My POE Switch supports 30W in the 802.3at but probably does not have CDP and LLDP. Because in the GUI I do not see them in the status. The strange thing is that the SSID appears on the air for less than 3 minutes and goes down. Although there is an enable status in the GUI.
What does the following log entries mean?
AP70B3.17A2.8FAA#show ip interface brief
Interface            IP-Address      Method   Status                 Protocol   Speed      Duplex
wired0               192.168.11.217  DHCP     up                     up         1000       full
wired1               unassigned      unset    down                   down       n/a        unknown
auxiliary-client     unassigned      unset    up                     up         n/a        n/a
wifi0                n/a             n/a      administatively down   down       n/a        n/a
wifi1                n/a             n/a      administatively down   down       n/a        n/a
