12-19-2012 05:56 AM - edited 07-03-2021 11:14 PM
Dear all,
I am trying to create some WLAN templates on the NCS (v1.2) and apply them to our WLCs.
Does anybody know how can i assign mobility anchors to a WLAN with a template apart from a CLI template?
I searched the NCS configuration guide and i foundthat i can assign a mobility anchor to a WLAN using the Configure-->Controller-->WLAN path. No templates option available.
Then i thought i could create a new Controller configuration group and assign the WLAN templates and the CLI templates (with the anchors configs) to the group. Unfortunately the CLI templates are not available there....
Is a CLI template my only option?
Thanks for your help.
12-19-2012 06:46 AM
From NCS you will need to use a CLI template. Or depending on how many WLC you have just do it manually.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
12-19-2012 08:09 AM
Yes, Correct. The templates won't have that option.
It has to be done using CLI templates or individually on a per controller basis from NCS/Prime Infrastructure.
12-19-2012 08:11 AM
Thank you for your immediate response.
