Cisco Wireless IP addresses
JAYESH RAMAIYA
Can you please have a look at the config below. We have three Cisco Wireless AP's in a school that are currently being used. This is a very similar config for all three AP's.
I would like you to look at the IP address 10.38.208.202. The other AP's have 10.38.208.201 and 10.38.208.200 with a 255.255.240.0 mask.
If someone conntected to the wireless why would there not be an IP address conflict?
Current configuration : 2275 bytes
version 12.3
no service pad
service password-encryption
hostname abc2
enable secret 5 H30cuCGy$1y2CqjIfDj83fmrlkMnw41
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server tacacs+ tac_admin
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
dot11 ssid abc1
   authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid abc1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no power client local
power client 50
power local cck 50
power local ofdm 20
channel 2462
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.38.208.202 255.255.240.0
no ip route-cache
ip default-gateway 10.38.208.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 5 15
Stephen Rodriguez
I'm not sure I understand your question.
If you didn't take these addresses out of the DHCP pool, you could potentially have an ip conflict.  But knowing that you are using these, you should make sure to exclude them.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
