Azure AD authentication on Meraki WiFi
CRUZPEREZ518
Will it be possible to authenticate users to my WiFi network using Azure AD?
I currently have it configured to authenticate using Active Directory and it works fine.
I have seen that it can be done through google, facebook, AD, etc., but I am interested in doing this configuration since we do not plan to migrate to Azure AD, or any alternative to solve this issue.
balaji.bandi
I believe they directly not supported last I read the documentation, not sure is this changed now :
https://community.meraki.com/t5/Wireless-LAN/Azure-AD-authentication-on-Meraki-WiFi/td-p/50285
check this BLOG may help you, ( we use ISE with Azure)
https://apicli.com/2021/12/13/meraki-mr-802-1x-with-azure-active-directory/
BB
