Mess code in AP9130
Leftz
Level 9
Level 9
Hi, when some of AP9300 is up, we can see below mess code via console. Why it happen? I checked internet for the reason. some of them say it is speed issue. but in my case, speed config is good and some of AP do not has the issue. Thanks
[01/01/1970 00:00:00.0000] Ig+-_i+g +e+-_y _a+ge 0|40000000 - 0|41000000
[01/01/1970 00:00:00.0000] Ke_+e+ c-++a+d +i+e: c-+_-+e=++yMSM0,9600+8 +bi.++d=7 _--+=/de+/_a+ ac+i+e-a_+=-a_+1 ac+i+eb--+=0 b-a_did=0|f _+i-++b=1 c_a_h+e_+e+=128M@2816M
[01/01/1970 00:00:00.0000] CPU1: B--+ed _ec-+da_y -_-ce__-_ [410fd034]
[01/01/1970 00:00:00.0000] CPU2: B--+ed _ec-+da_y -_-ce__-_ [410fd034]
5 Replies 5
balaji.bandi
AP9300  - what is the correct model?
why does that time show 01/01/1970 ?
is the AP working as expected? and only have a console issue?
BB
Leftz
Level 9
Level 9
@balaji.bandi Thanks for your reply. its new c9130. when i configured first one, everything is ok, but second and third one have the issue. I have not accessed via cable yet
All are the same models ( one works rest all have the same issue ?)  i have not experienced this issue anytime before.
Try reset to the factory and testing it. also, have you tried different baud rates? (just to check) - since you confirmed one working I don't expect to be baud, but worth testing.
BB
Rich R
There are numerous USB console cables around which will not work at all or will not work properly with Cisco APs.
Generally cables based on genuine (not fake) FTDI chipset are very reliable.
If it's Prolific or some other chipset - good luck.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Leftz
Level 9
Level 9
Thanks for your reply. Do not know why the issue disappear without any treatment
