Best configuration for 802.11ac W2 with WLC + 3650 + Mobility Express APs
Ricardo Duarte
Hi there,
I currently have two 3650 switches (IP Base; with AP licences; not stacked), ten 3800 802.11ac Wave 2 Access Points with Mobility Express Licenses and one WLC 5508 with 12 APs licensed. The 3650 are MGIG capable.
I would like to be able to switch the traffic at 5Gbit, so Local Mode on the WLC is not an option.
I see the following options:
Option 1:
Use Mobility Express on the 3800; connect APs to the 3650 (5 Gbit/s); any AP can become a Master controller so availability is high; but it does lack mdns and the controls I have with the other options
Option 2:
Make each 3650 a controller, and add them to the same mobility and radio domain; that way, if one of the 3650 goes down, I still have a network.
Option 3:
Use 5508 and setup APs as Flexconnect
Are there any other options?
What would be the best wireless configuration with this gear that provides the best availability and performance?
Thanks.
Hi Ricardo,
If I were you, I would choose option 3
Rikshit
