Bridge link between two 1310's not working
hkgadmin1
Hi all,
I have two 1310 bridges which im trying to configure. Ive had them working a long time ago, but they were reset recently and need reconfiguring.
I followed the Cisco guide for a point to point wireless bridge however I continue to get an error on the non root (regardless of which one is configured as the non root):
Interface Dot11Radio0, changed state to administratively down
Warning Interface Dot11Radio0, cannot associate: No Response
At this point, the interface stays down and i have to do a shut, no shut to get it to reattempt.
I tried a config with no encryption or authentication and got the same result. Can anyone offer any advice for how to troubleshoot this problem?
drgebhardt
Had a similar problem with 1242 used as a bridge. The resolution was to restore to factory defaults and reconfigure. I was also told or read that configuring and bringing the non-root bridge first helps. Hope this helps.
Hi drgebhardt,
Sorry for the delay in response, and thank you for the reply.
The units were reset to factory defaults, however I have not tried setting up the non-root first.
I'll give this a go tomorrow when I am able to get back to the units.
Greg
