07-26-2024 01:47 PM
Hi, I'm getting a surplus C1111-4PWE .
Can the embedded WiFi AP be used independently, or will it only work when connected to or controlled by a separate Cisco controller?
Solved! Go to Solution.
07-26-2024 05:15 PM
You can deploy Mobility express so AP act as Controller and broadcast SSID:
07-26-2024 05:15 PM
07-26-2024 11:18 PM
Excellent, many thanks. I will try this shortly...
