C9115 power up problem
sshahul12
Frequent Visitor
Frequent Visitor
Hello
i have a Cisco C9115 Access Point with embedded controller , i tried booting with several POE switches such as 2960S and 2960X and even 9200 series but while in some cases it boots normally in some other cases it seems device is not working properly and even Ethernet port of the radio can not ping via a direct cable connected to same switch - the product data sheet saying even with POE+ switches it should be come up normally. should it be a power issue? because while using 9200 series POE switch problem happens lesser but again in some cases Ethernet port is not accessible , please help me.
thank you in advance
Shahul Eassa
Mark Elsen
                                      >... should it be a power issue?
  - That depends , if you can not ping it then that might be a basic networking problem such as port setup  , port-configuration and vlan assignment (e.g.) , POE problems are usually shown with different led flashing colors in subsequent order on the access point, best is to attach a console to the access point and scrutinize the boot process.  If it's available on the network and you can connect to it then issue the show logging command just after boot, look for errors related to powering the AP , if any ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Scott Fella
Like @Mark Elsen mentioned, take a look at the output of the console while you are booting up.  You will see what the issue is, and if the ap does boot up, you can always try to ping from the ap out.  Might just be a simple basic network issue on your switch.
-Scott
Rich R
Note that for POE+ (802.3at) to work correctly CDP or LLDP must be enabled on the switch port otherwise the AP will use standard POE (802.3af) at 15.4W.  However the 9115 will still work at 15.4W but with reduced features as per https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/datasheet-c78-741988.html#Productspecifications
As the others have said already watching the AP console from power on will tell you exactly what is happening on the AP.
Also make sure your software version is up to date as per the TAC recommended link below.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
