C9115 running Embedded Controller
mumbles202
Level 7
Level 7
This is my first time using the 9115s and looking to see where some settings would be.  I was able to create a policy and key in a vlan under the access tab, but was curious if there is an option for named vlan/vlan groups from the gui like in a 9800?  Also, I can't seem to find the location to do a backup of the configuration from the GUI.  I can ssh to the unit and grab the show tech wireless but don't see where to export/download the configuration file in case a restore is needed.
6 Replies 6
balaji.bandi
have you tried going to advanced mode
https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
BB
Thanks for the reply.  I thought there was an advanced before I upgraded to 17.6.4 code but not seeing it now, unless I'm looking in the wrong place.
NVM - found it under preferences.  I see where to add another SVI under Layer 2 --> Vlans, but not seeing vlan/vlan group that I'd then be able to select from drop-down under my Policy.  Exported the configuration (show tech wireless) and ran it through the configuration analyzer (not 100% sure it works for the embedded controller as well as a standard 9800) and I'm seeing this error:
Authentication: Profile(s) with AAA Policy pointing to non-existing value. Profile: Guest_Wireless,Profile: Staff_Wireless,Profile: default-policy-profile
Action: Check the configuration item, and change/replace it with an existing value
But looking at the configuration I have this:
wireless profile policy Guest_Wireless
 no central association
 no central dhcp
 no central switching
 vlan 100
 no shutdown
wireless profile policy Staff_Wireless
 no central dhcp
 vlan 20
 no shutdown
wireless profile policy default-policy-profile
 no central dhcp
 description "default policy profile"
 http-tlv-caching
 ipv4 flow monitor default-flow-monitor input
 ipv4 flow monitor default-flow-monitor output
 no shutdown
wireless tag site default-site-tag
 description "default site tag"
 no local-site
wireless tag policy default-policy-tag
 description "default policy-tag"
 wlan Guest policy Guest_Wireless
 wlan Staff policy Staff_Wireless
wireless tag rf default-rf-tag
 description "default RF tag"
wlan Guest 2 Guest
 security ft
 security wpa psk set-key ascii 0 Guest_Wireless!
 no security wpa akm dot1x
 security wpa akm psk
 security wpa akm sae
 security wpa wpa3
 security pmf optional
 no shutdown
wlan Staff 1 Staff
 security ft
 security wpa psk set-key ascii 0 Success123!
 security wpa wpa3
 no shutdown
don't have device access now to provide the right direction for you, I am sure there should be.
BB
Thanks. I just want to setup a simple SSID with PSK and have users get an ip on vlan 20 or 100 depending on which SSID they are connected to. Is the above corrector am I missing something?
Rich R
Remember the EWC on AP only supports flexconnect local switching and the EWC and AP can only use IPs on the native (untaggged) vlan - no vlan support on the WLC itself because it does not support central switching at all, only management.
So all VLAN definitions must be in the flexconnect profile and then it's same as always.  If you use vlan names (you can also use numbers - just type the VLAN ID) then those names must be defined in the flexconnect profile.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thanks for the reply.  At the moment I'm not able to test the configuration to confirm I get an ip, but I have all the interfaces facing APs set as trunks so running in FlexConnect should be fine.
Does the above configuration appear correct?  I'm not sure if the Configuration Analyzer works for the 9100 series running the embedded controller.
